New member with my first post, I poked around a bit, but wanted to verify.
Quick background, I go back to the X10 days and had a fair amount of stuff in the house controlled that way. Over the years, that morphed out and into a mix of various odds and ends systems (with a couple of X10 devices still running).
After some (too much) time researching, finally decided to switch to something centralized. I have started setting up Hub and playing around with a couple device types, to get comfortable with it.
Most of my needs are pretty straight-forward plugs and switches, however there is one item that I want to make sure I understand. During my X10 days, I added some gallery track light for artwork on the wall, I did it by installing ceiling boxes and pulling power in the attic. I did not mess around with running wiring through the wall, adding box/switch, etc., since X10 had inline modules that I just put in a box in the attic and use an X10 controller for them.
To replace that now, am I correct that I need something like this ENERWAVE Z-Wave Plus Relay:(https://www.amazon.com/Enerwave-ZWN-RSM1-PLUS-Wireless-Control-Required/dp/B01G7OD1F8) in my attic to replace the X10 devices?
Also if that is the device I need, I didn't see any that are dimmers (or maybe I'm just searching wrong).
Or would it be just as simple/or cheaper to throw a couple of Z-Wave wall dimmers in box in the attic (they would just never be used)?
Thanks in advance for any thoughts.
