HSM appears to be a great tool to monitor if a door was left open for x amount of minutes but I am curious on a couple of things.
This causes an alert that needs to be cleared in HSM. The simple solution is to just close the door. Do I need to clear this alert? It's not always convenient to get into the hub and clear the alert.
If the alert isn't cleared and the door is left open again later in the day will alerts be suppressed or will the monitor rule still be actioned and alert me after x minutes?
I haven't tested this yet but do alerts come every x minutes if the alert isn't cleared? I currently have it set to alert me every 5 minutes if a door is left open. Just curious if I close it and not clear the alert if I will receive alerts every 5 minutes.
Sounds to me like HSM isn't the right app for what you want. Try using Rule Machine instead. With HSM, you will need to affirmatively clear the alert. This could be done automatically with an RM rule, but by that point why bother with HSM. Just use a rule that alerts you when a door is left open for x minutes.
Condition: Door open
Rule: Door open
Action for True: Delay with cancel x minutes, send alert
Action for False: (none)
If the door is closed before x minutes, the rule flips to false, and the alert after x minutes is cancelled.
Thanks @bravenel for the great advice. I will set this up in Rule Machine. I had a hunch rule machine would have been the better option when I set this up.
