Qubino Shutter - Wrong direction in calibration
So I have this working fine via my 3 way wall switch - press Up, goes Up. When I request to calibrate the blind goes down up down instead of up down up. I guess I could swap the cables at the wall switch but then of course if I /someone uses that it will go the wrong way.
Is there a way to configure the Qubino to swap its direction for u/down?
Alternatively I guess I'll have to not use auto calibrate which is a shame as works fine on the other 2 blinds
