How do you edit the stop position of roller shades?
I have 1 set that I don’t want to close all the way - when I close it, I want it to stay open by about 18 inches.
Using the set position command, I’ve found that this is “position 35”.
I’m stuck trying to figure out how to program the qubino to use that position is the stop position when closing the shades. If i set the position to 35 and then press “stop position change” it ends up setting that position as the open position.
Is it possible to do what I’m trying to do?
