I'm on C7 now and most things are eventually fine but I have this peculiar problem with Qubinos that is braking some scenes and automations.
See the log below where I use the device page to
- turn the device on
- set the level to 30
- set the level to 25
Note the log reports 30 OK and then 24, not 25. For a scene where the device is set to 25. The set level become 24 and the scene activation switch never comes ON which brakes triggers and rules.
When this happens, I also get the time glass forever on the device tile on the dashboard and status is wrong on the device page.
If I try other levels where set level and log output is right (like level 30 in the example above) everything works like a charm.
Could this be influenced by device parameters for minimum and maximum brightness? Currently they are set to 15% (min) and 85% (max).
I checked another Qubino and got this (consistent over two different devices)
Set Level / Reported Level (log) / Min Brightness / Max Brightness
30 / 30 / 15 / 85
25 / 25 / 15 / 80
25 / 24 / 15 / 85
It looks all wrong to me that reported level is slightly off compared to set level. Round issue in the stock device driver? Firmware problem with the Qubino device?strong text
