Qubino Flush 1d Relay
I have a qubino flush 1d relay which I want to use as a garage door opener.
I currently have a Meross wifi garage door opener which is connected to the actual garage door opener. I am hoping to replace this for the qubino.
I have added the device to Hubitat and can hear the switch clicking when activated via the on/off.
However I don't know which of the terminals to use for connecting to the opener.
So I have N L Q(down) Q (up) I1 I2 TS.
So I am using N and L to connect to the mains via a standard UK 3 pin plug.
How do I wire the rest of it?
Many Thanks in advance.
All sorted now. My wiring was correct. I just needed to change some of the device preferences.
I'm getting ready to install one of these as a gate controller. At this point, I don't have a sensor, but hope to add one soon. Like a garage door opener, my gate has a single button for open and close. Do you mind sharing what settings you used on the 1D relay? Also, what template are you using for the dashboard? I'm still new to Hubitat and learning something with each device installed. Thanks in advance.
[quote="sctnelson2001, post:3, topic:52632, full:true"]
[/quote]
switch template for dashboard but we usually use alexa.. "close the dog gate" or open the dog gate both a routine that just turns on the switch.
