Now that Weather Underground has started providing API key's for PWS providers, I'm code illiterate, and don't have something set right it appears. I'm using the WeatherUndergroundCustomLowerCaseOnecall driver and have this error in my logs, any on how to correct this or maybe a better driver is appreciated.
Which driver are you using?
You need to enter your API key. Did you do that?
Yes the API key is entered and from what I can tell is working as in the logs has the accurate temp humidity wind etc listed as being polled.
Sorry, never heard of it. Best to contact the driver author.
A long time ago, I had a driver with the first part.
But that was depreciated a long time ago.. maybe someone is still developing it
I have no idea what One Call is
It does have you listed as the author I believe
I never wrote anything for one call so I assume that someone took my original driver and added/changed it.
Do you have a different one you'd recommend?
Is your depreciated driver still available? I'm still using your old one and it's not giving me any trouble.
Which one?
'Weather Underground Custom'??
Custom WU Driver
I haven't recoded anything for WU changes as I have not needed to for my Weewx/Wu driver
To be honest, I haven't even looked to see if any changes are needed.
BTW @waynespringer79 you can find my drivers here: http://hubitat.uk
I have the Custom WU Driver as well, I'm switching to that and see if I can get it to work.
Same here. All that effort for the Weewx driver and WU just keeps bowing to consumer pressure.
Shouldn't be a problem. Andy writes good code. You just have to accept that, the driver has no support as it's depreciated.
I have to say though that I like weewx.
Same. I'm kind of looking forward to using it, but so many other things to do, so kind of glad I've not had to deal with it. I pretty well forgot everything that took me weeks to learn about it.
BUT!
I also have to say that I would not have bothered if WU had not told everyone that they were stopping the feed
I'm just glad it's already installed.. can't remember how to do it ![]()
I looked at the WeeWx and everything else in this community trying to get this up and going, I'm just not code smart enough to figure it out....when I looked at WU and the statements that they were returning to providing the API's for PWS owners I figured I would try that route to see if I could get it to work.
