just wondering if its possible to speak the message on phone.
for example, I get the notification and right now its just a chime sound..
Could I get a notification using TTS .. Motion detection at back door, or front door, or in yard
Only on certain speakers or devices, two with built-in support are Chrome Cast (Google Home devices) which works most of the time, Sonos always works, Echo devices work with Echo Speaks, although I haven't tried. There are probably a few other methods. I also used a Aeotec doorbell gen 5 to play custom mp3 files on a hub that was not connected to the internet.
Short answer - on a phone, no. You could probably send an mp3/wav file but if you are expecting your phone to suddenly wake up and say a message out of the blue, then no.
See posts #4/5 below
If you have an android phone, there might be a way using tasker. I used to have tasker setup to tts my incoming text messages when I had a Bluetooth headset on. Its been a while since I played with tasker, but might be an option.
Can tasker read texts automatically? If so you should be able to send an SMS from HE although this will not be free Twilio - Hubitat Documentation
EDIT: Ah yes, I haven't used tasker in a long while as I've already got it set up to do what I need it to, I'd forgotten that tasker can initiate actions by monitoring for incoming calls or texts. I stand corrected on my negative statement above.
