I’m hoping for some whiteboard level spitballing pros/cons trying not to indulge in my many biases!
In general, I have devices that 100% need to go through my HE C-7 then be presented to HomeKit to control with Siri, etc. as some devices aren’t supported directly by HomeKit but work fine using this integration.
HomeKit’s ability to automate has taken serious strides as of late. I know there’s some hard core Home Assistant buffs that have moved their “main” functionality to pure HomeKit. They still tinker and do experimental stuff in their HA, but the “absolutely has to work or significant other be dammed” stuff has been all migrated directly to HomeKit.
My components: HE C-7, Lutron Pro, HomeKit controlled by HomePod Mini(s) and everything must run local, work even if my Internet connection is down.
I’m about to start a migration from Alexa to Siri and I’m in the planning stage so I want to consider all options before I do this full tear down and re-architect.
My first thought was to connect EVERYTHING to Hubitat and then use this integration to present to HomeKit, but then I started second guessing myself and now what about all the other functions too?
Where should I create the Groups/Rooms?
Where should I create the Automations, if I one day start using some?
What should I present directly to HomeKit vs. Hubitat?
Should I create the Scenes/Routines in HE then present them to HomeKit or directly in HomeKit?
I honestly don’t have any automations I rely on, everything that combines actions is only via Routines. I’ll tell my assistant to set the room for bedtime and I want lights to do things and specific white noise to play from Apple Music, etc., but I don’t have any sensors yet other than a HomePod Mini in reach room of the house grouped to the room’s lights and their built in presence and temperature sensors.
I’m torn if I should present everything directly to HomeKit and only things I need to Hubitat or not. I can’t decide if I should create a Room called Bedroom in Hubitat and then present it to HomeKit or just push all HE devices to HomeKit and then create Rooms there, or create the Room in both?
Right now I’m leaning towards connecting EVERYTHING to Hubitat in one big pool/group/room or whatever and push them all to HomeKit as individual items and then I’ll create all my groups, rooms, routines, automations (some day), etc. in HomeKit.
Thoughts?
