Hello:
I installed this device...
and Hubitat (C7) automatically assigned it the "Generic Zigbee Multi-Endpoint Switch.
It works as long as I press the buttons on the actual switch. I can turn on and off each of the 4 switches independently and Hubitat recognizes them properly.
However, when I send a command from Hubitat to turn one switch on (or off) all 4 turn on (or off) at once.
I cannot control the 4 switches independently from Hubitat.
This is in contrast to some MHCozy 4 channel Relays that work as expected with the built-in "Generic Zigbee Multi-Endpoint Switch".
Rufus suggested a driver called "Zemismart Zigbee Wall Switch Multi-Gang" to be installed with Package Manager, but I get the same results.
Does anyone have any experience with these devices or can suggest a way to diagnose this issue?
Thanks, Mark.
