This app works by being a parent and child of itself. The Hubitat team stated at some point that they didn't like that functionality which was a carry over from SmartThings. I'm guessing they axed it finally. Maybe I'll take a look and try and refactor into a child and parent app. I'm not excited about that since this is something I don't use and it hard to troubleshoot because I don't have the hardware.
Is anybody that is actually using this and has a Hive system have any development skills?
*edit: Just out of curiosity what happens in you try commenting out (or deleting if you don't know how to comment) the parent line in the definition and saving it?
Does it work? Then if you put it back to original and save again does it work? You might be able to fool it that way.
Yeah, that seems to work. You can remove this line (line 69):
parent: "alyc100:Hive (Connect)",
Then you can save it. Then put the line back. Save it. At this point it didn't let me create one of the apps so I rebooted my hub. Then it let me do it. Someday hopefully somebody with one of these devices can do some refactoring for you.
A couple of hours for the experienced to a couple of days for the inexperienced probably. It should be mostly copy and paste work that would move some functionality out of the parent into a separate app (child).
Ah thanks for letting me know. I ended up having to ditch the app all together it had a weird interaction with my heating and wouldn't let it turn off, kept flicking it back on...I went with simplicity and used IFTTT
I've got a couple of rules to override the schedule, i.e. if someones home when they wouldn't normally be and to make sure it knocks the heating down when we are all out when we wouldn't normally be.
If i can be of any help i'm happy to, but my coding skills are non exsistant.
Awesome, keep us updated. I like hive but there are a lot of things it can't do natively. Like switch off when away or switch on when you're coming home.
We also had issues with holiday mode seemingly disabling itself.
All those can be worked around, I use IFTTT and hopefully if you buy and work on the app via hubitat.
That would be great. I don't have one of these so it's super low priority for me to keep updated. If you end up getting one I would be thrilled if you took over this integration.
I have been writing a zigbee driver for Hive and got the basics working but there are some weird quirks I'm struggling to debug. I have made a request for hive to release their spec but they have refused. I have now made a request under the data protection act to extract my data from the device to see what response this yields.
Here is a bit of a thread on what I have been doing with zigbee. If people want to pile on with Hive lease head over to their community and given them some grief about not opening up their spec.
@rob if you ever got it installed the coding @dj_bayley has been working on might be of some use for you guys to pick up and get it working for us all and @Baz2473 I saw your input into previous posts too.
Just trying to get Hive working. Tried following the advice on here, and always get errors when I save. I can't follow the GitHub links as they give a 404 error. Anyone have the code handy?
I don't have much Dev experience, but I'd be happy to help (eg with testing) if you get anywhere on this.
At a minimum, just getting Hive thermostat and TRV temperatures reported back in Hubitat would be very helpful for automations and graphing - currently doing this a very hacky way with a series of homekit automations changing a virtual thermostat to mirror the TRV readings... not great!
