HI,
The new drivers are looking good...I don't have the messages in the log file anymore, and everything is working as it should.
Thanks so much for your assistance.
HI,
Updated Version(s):
Change(s):
Note(s):
Updated Version(s):
Change(s):
I recently implemented these drivers in my setup but can't seem to get "real time" updates from my All In One Sensor. I can manually refresh it and it's updating, but I needed automated updates. I believe this is possible, but must be missing a setting somewhere.
Any recommendations to troubleshoot or setting to confirm would be appreciated! ![]()
I'm trying to set up for the first time and getting the following error when trying to login.
Level
Clear filters
dev:502025-03-29 11:55:45.918 AM
error
java.lang.ArrayIndexOutOfBoundsException: Index 1 out of bounds for length 1 on line 996 (method Login)
@kevin9: Sorry, somehow I never saw that you had posted here. You can get the "live" type of notices by enabling WebSocket Monitoring in the parent device's Preferences. Otherwise it only updates data as it polls for it, but WebSockets are sent right from the controller.
@user588: That error means it did not even provide information because it could not even run the split command to determine what the actual response error was. It is not great that it happens (I will have to make a change to check for that scenario) but it means it was not going to work anyways. Could this be related to the same unauthorized problem you were having with the Network drivers?
I figured out that I needed another firewall rule set up. Now I'm getting the same 401 error that I get in the networking app. My protect app is running on an NVR and yes, It also also has a local account I'm using for the log-in.
So I've still not been successful in getting connection to the protect controller which is a UNVR. Still getting the 401 error. I've tried creating a second local super admin account and have tried setting the device as the UDMP. I've tried ports 7443 and 443. Any other ideas?
It should use the exact same settings as the ones for the Network API portion. The login for that one should work for the Protect as well, and the Preference settings can be the same (the underlying login is the same, it is how they request data and what they provide that made it easier to have two driver sets).
Are you saying I should use the IP address and login for the cloud gateway and not the UNVR?
Hmm... I am used to dealing with one system that provides both Network and Protect APIs (and more, since I have a UDMP). If I remember correctly in this case, Protect runs on the NVR while Network runs on the Cloud Gateway Ultra... so you are correct, they would be different since the Ultra does not support Protect. (I had to look this up, as the Max does, and that is the most recent Cloud Gateway I have talked to someone about I think).
The port should be 443 in this case as I would assume you have the latest version firmware on the NVR. It is likely using the UDMP methods... but you indicated you have already tried that. The NVR has a different admin user than the UCG Ultra, correct? Like with that one for Network, the easiest test is to login directly to the NVR's web interface with the user to make sure it has access.
The
I have confirmed the login works. I do have another http debug line showing up in logs. The NVR is on it's own VLAN but firewall rules look fine and not seeing any blocking happening in the logs. Some screenshots below to help.
I would try setting it to the Unifi Dream Machine controller type, Save Preferences, then do the manual "Login" command on the device's Commands tab... [Fingers Crossed]
So super weird on a few levels.
After trying the Dram Machine type (I had done this before) it gave me the error again but as a debug type. " debug Expected HTTP 101 response but was '401 Unauthorized'". So I tried changing the port again to 7443 and it logged in! Protect did update to the new version over night so maybe this has something to do with it?
The other weird thing I notice right away is that is shows one of my APs under child devices.
The device type name for the NVR is UNVR4 if you want to add that to the firmware. Let me know if you want me to check anything else.
So, I want to confirm a couple things and some responses:
1 - Yes, confirming it is now working
2.1 - Regarding the controller type, It did require UDMP as the controller type.
2.2 - After changing the UDMP type and saving, it was still erroring out with the debug error and the option was still there for changing the port. After changing the port to 7443, it started working
2.3 - I updated the Hubitat firm ware after getting it all working, and after checking this morning, the port number selection is no longer showing.
Thanks for the other info! Good to know.
@fleetmack: In response to the post on the Network controller project:
Thanks. I enabled Trace. If I push the "push" button here:
....my rules work. I get notifications, my speakers speak, etc. But pressing the button on the doorbell does nothing.
Do the logs show any WebSocket activity? With Trace logging enabled on the parent device your log should be full of things that start with "WebSocket Data = " and "WebSocketStatus = ".
