[PROJECT] Driver for Unifi Connect
Overview:
This is a parent/child set of drivers in order to read data from your Unifi controller's Connect API and provide some information that may be useful to your Hubitat. It also allows for some commands to be sent from the Hubitat back to the API for limited control of Connect features, geared around the device-specific child drivers. Like most of my drivers this will be a perpetual project and I am always open to feedback.
Features:
  • Create supported child device(s)
  • Ability for specific device features such as turning on/off, setting volume, setting brightness, etc...
  • Daily check for new devices added to the Connect API
  • Daily check for new driver versions. It will NOT load updated drivers, just post an event that a newer version is available.
Driver Links:
Setup:
  1. Add UnifiConnectAPI.groovy driver to your Drivers Code section on your Hubitat (you can Import using the URLs above) then Save the driver. Or you can use HPM.
  2. Add a Virtual device and set the Type to be UnifiConnectAPI (user-added drivers are going to be at the bottom of the list), then Save Device.
  3. Enter your Unifi Controller's IP/Hostname, Username, and Password into their respective fields in Preferences, select your Unifi controller type, then Save Preferences.
    REQUIRED: With changes to the way Ubiquiti handles accounts, you need to create an admin-level account on the controller directly that has local-only access and does not rely on Ubiquiti's cloud. Create the new account and select the "Restrict to local access only" checkbox.
    REQUIRED: If you use a Controller Type of "Other Unifi Controllers" go back to the Preferences after you save. There should now be a field showing Controller Port # that is required. This defaults to the typical 8443 but newer Controller versions may be using 443.
  4. OPTIONAL: Add any specific child drivers using the same method as step 1.
Caveat(s) / Known Issue(s):
  • Very little data is posted to devices at this time. There is more data that has been identified and will be added but I wanted to get some basic functionality out there for everyone to try first.
  • The Connect API provides VERY limited responses to actions sent compared to other Unifi APIs. The driver attempts to work around this by populating data based on the success or failure response.
Thanks so much, I got the drivers installed, but it did not identify my display 13 correctly just assigned the ConnectChild driver, so I changed the driver to the display 13 and then tried to control the device with just the options and nothing happens with any of them.
What do you need from me?
Looking into the logs you sent me to try to figure out where I went wrong for the Display 13... Sorry about that.
Thanks for everything, its working great now!
Updated Version(s):
  • UnifiConnectAPI.groovy = 0.1.3
  • UnifiConnectChild-UC-Display-13.groovy = 0.1.1
  • UnifiConnectChild-UC-Display-SE-13.groovy = 0.1.1
  • UnifiConnectChild-UC-Cast.groovy = 0.1.1
  • UnifiConnectChild-UC-Display-7.groovy = NEW, link added to thread's initial post
  • UnifiConnectChild-UC-Display-21.groovy = NEW, link added to thread's initial post
  • UnifiConnectChild-UC-Display-27.groovy = NEW, link added to thread's initial post
  • UnifiConnectChild-UC-Display-SE-7.groovy = NEW, link added to thread's initial post
  • UnifiConnectChild-UC-Display-SE-21.groovy = NEW, link added to thread's initial post
  • UnifiConnectChild-UC-Display-SE-27.groovy = NEW, link added to thread's initial post
  • UnifiConnectChild-UC-EV-Station.groovy = NEW, link added to thread's initial post
  • UnifiConnectChild-ULD3AC.groovy = NEW, link added to thread's initial post
  • UnifiConnectChild-ULP3AC.groovy = NEW, link added to thread's initial post
  • UnifiConnectChild-ULP3PE.groovy = NEW, link added to thread's initial post
Change(s):
  • Added support for all devices currently listed in the API's responses (see specific child drivers).
  • Overhauled how actions were performed from the existing child devices.
Note(s):
  • After putting a bunch of work into getting all the different displays added specifically... I have been thinking of a way to make a single display driver that would make all the current 8 obsolete. Something for the future.
  • There is not much difference (from the API or driver perspective) between a Display and a Display-SE. If you are not sure which you have, add both child drivers. You can always delete the unused one. In the future, if I can get a consolidated Display child driver made it will not matter anyways.
Updated Version(s):
  • UnifiConnectAPI.groovy = 0.1.6
Change(s):
  • Change to how the CSRF value is received when a login attempt is made. In version 3.2.8 of the Unifi OS they changed the header's case... Yes, something as simple as changing it from X-CSRF-Token to X-Csrf-Token broke it. So the device was not actually capturing the latest CSRF so actions could no longer work. I was recoding it when @tomw provided a better method of changing it's case and comparing it to that. So now, even if they change it to x-CsRf-ToKeN (or any combination thereof) it will still work.
  • Changed the WebSocket portion to match what I have in my Protect driver
  • Cleanup of copy-paste error in login section
  • Change to error logging for login
Updated Version(s):
  • ALL DRIVERS UPDATED
Change(s):
  • Support for new authorization Token used by newer Unifi OS versions.
  • Replacement of driver-specific variables "Driver Name", "Driver Version", and "Driver Status" with ones that do not have a space. This will take effect the next time you Save Preferences on a particular device.
  • Correction to ProcessEvent function.
Unifi is enforcing MFA, which method is compatible with this driver? Thanks!
If you use a local (to the Unifi controller) account with admin access it will work with the driver. So when you are going to add a user on the controller, select the "Restrict to local access only" checkbox (screenshot below). Those do not require MFA.
LocalAdmin
Perfect thanks. solved.
To make sure I understand — wouldn’t this mean one could not setup your drivers while on remote VPN? We have a second home with a new UDM Pro and I’m trying to use your awesome drivers but I’m having trouble logging in (using the same credentials that work from a browser directly). I’m thinking it might be because I have MFA enabled.
But if I create a local user without local access, then it would seem I’d have to wait til the next time I’m at that location to set this up. Or am I overthinking this?
The MFA causes a lot of trouble for a set of drivers that are local only to the network. If you VPN into that remote network, you could set things up remotely... but the Hubitat has to be able to reach the same network the Unifi controller is on.
So... if the Hubitat can reach the IP/Hostname of the controller, you should be all good with a local account on the controller (because the Hubitat is "talking" directly to it). If the Hubitat cannot even get there to begin with, then my drivers will not work (because none of them go through Ubiquiti's cloud).
Gotcha OK thanks.
For others that follow: you have to create a user account without 2FA per @snell’s entry in this thread 4 messages above. Then it works like a charm
I am adding that to the initial post instructions right now.
Updated Version(s):
Change(s):
  • Inclusion of code to support @mavrrick58's Integration app.
  • All drivers have been updated to the latest methods I am using for Events, States, and Tiles.
  • Additional data handling has been added for new variables reported within the API.
NOTE(s):
  • These drivers have now been added to my HPM repository.
