Sorry for the delay on getting the over to you, but here is my entire status.json. Hope this helps.
{"istat":{"hostname":"apex","software":"4.53J_4D19","hardware":"1.0","serial":"AC4J:13571","extra":{},"timezone":"-4.00","date":1654691190,
"feed":{"name":0,"active":0}
"power":{"failed":1654690897,"restored":1654690945}
"inputs":[{"did":"base_Temp","type":"Temp","name":"Tmp","value":74.0 }
"outputs":[{"status":["AON","","OK",""],"name":"OaseFilter","gid":"","type":"outlet","ID":0,"did":"base_Out1"}
,{"status":["AOF","","OK",""],"name":"OaseHeater","gid":"","type":"outlet","ID":1,"did":"base_Out2"}
,{"status":["AOF","","OK",""],"name":"CO2Sonenoid","gid":"","type":"outlet","ID":2,"did":"base_Out3"}
,{"status":["OFF","","OK",""],"name":"Unused","gid":"","type":"outlet","ID":3,"did":"base_Out4"}
,{"status":["AOF","","OK",""],"name":"SndAlm_I6","gid":"","type":"alert","ID":4,"did":"base_Alarm"}
,{"status":["AOF","","OK",""],"name":"SndWrn_I7","gid":"","type":"alert","ID":5,"did":"base_Warn"}
,{"status":["AOF","","OK",""],"name":"EmailAlm_I5","gid":"","type":"alert","ID":6,"did":"base_email"}
,{"status":["TBL","","OK","1000","-620"],"name":"Macros","gid":"doser_2","type":"dos","ID":7,"did":"2_1"}
,{"status":["TBL","","OK","1000","-586"],"name":"Micro","gid":"doser_2","type":"dos","ID":8,"did":"2_2"}
],"link":{"linkState":3,"linkKey":"G9qXY7","link":false}}}
