[PROJECT] Driver for Blink API
I'm trying to think through how I can use the Blink cameras on my dashboard. My app uses the MakerAPI to get all devices/attributes/commands.
I see 3 cameras (type=BlinkChild) and 1 type=BlinkAPI device. Only the BlinkAPI device has the commands such as arm/disarm/enable motion/etc. The camera devices have a bunch of attributes but none of these commands.
Ideally, each camera would have some commands which can be applied just to the camera - like enable/disable motion detection, get thumbnail, video, etc (future stuff I know..).
Anyway, it seems like I'm going to need to display a dashboard tile for the overall Blink system and 1 for each camera. It'd be really nice if I could use that Thumbnail File image for the dashboard tile. That would make it clear which camera is which
    "name": "Blink",
    "label": "Blink",
    "type": "BlinkAPI",
    "id": "357",
    "date": "2020-09-25T00:51:00+0000",
    "model": null,
    "manufacturer": null,
    "capabilities": [
      "Refresh",
      "Sensor",
      "Actuator"
    "attributes": {
      "ClientID": null,
      "dataType": "STRING",
      "values": null,
      "Driver": null,
      "Updated": "2020-09-24T00:42:59+00:00",
      "Version": "Patch development 0.1.5 version"
    "commands": [
        "command": "ArmSystem"
        "command": "DisableMotionDetection"
        "command": "DisarmSystem"
        "command": "EnableMotionDetection"
        "command": "GetCameraInfo"
        "command": "GetCameraUsage"
        "command": "GetHomescreen"
        "command": "GetNetworks"
        "command": "GetNotifications"
        "command": "GetVideoEvents"
        "command": "RequestPIN"
        "command": "VerifyPIN"
        "command": "refresh"
    "name": "Camera-88951",
    "label": "Camera-88951",
    "type": "BlinkChild",
    "id": "359",
    "date": "2020-09-24T13:23:57+0000",
    "model": null,
    "capabilities": [
      "TemperatureMeasurement",
      "Battery",
      "Sensor"
    "attributes": {
      "Account": null,
      "dataType": "NUMBER",
      "values": null,
      "Account ID": null,
      "Alert Interval": null,
      "Alert Repeat": null,
      "Alert Tone Enable": null,
      "Arm String": null,
      "Armed": null,
      "Auto Arm By Geo": null,
      "Auto Arm By Time": null,
      "Battery Alert Account": null,
      "Battery Alert Count": null,
      "Battery Check Time": null,
      "Battery Number": "3",
      "Battery Status": "ok",
      "Battery Voltage": null,
      "Busy": null,
      "Camera Error": null,
      "Clip Bitrate": null,
      "Clip Seconds": null,
      "Clip Warning Threshold": null,
      "Created": null,
      "Daylight Savings Time": null,
      "Enabled": null,
      "Encryption Key": null,
      "Feature Plan ID": null,
      "Firmware Version": null,
      "ID": null,
      "Illuminator Duration": null,
      "Illuminator Intensity": null,
      "Issues": "[]",
      "LFR Alert Count": null,
      "LFR Channel": null,
      "LFR Strength": "5",
      "Last HB": null,
      "Last Snapshot Event": null,
      "LiveView Mode": null,
      "LiveView Seconds": null,
      "Liveview Bitrate": null,
      "Local Storage Compatible": null,
      "Local Storage Enabled": null,
      "Local Storage Status": null,
      "Manufacturer Mez Type": null,
      "Max Resolution": null,
      "Motion Detection Enabled": "false",
      "Motion Sensitivity": null,
      "Name": "front door",
      "Network ID": "39640",
      "Network Key": null,
      "Network Origin": null,
      "NetworkID": null,
      "Onboarded": null,
      "Ping Interval": null,
      "Privacy Zones Compatible": null,
      "Record Audio Enable": null,
      "SM Backup Enabled": null,
      "Serial": null,
      "Snapshot Enabled": null,
      "Status": "done",
      "Storage Total": null,
      "Storage Used": null,
      "Sync Module Error": null,
      "Temp Adjust": null,
      "Temp Alerts Enabled": null,
      "Temperature Alert Count": null,
      "Thumbnail": null,
      "Thumbnail File": "fw_7.96__Zi7psW4H_2020_09_18__12_44PM.jpg",
      "Thumbnail Image": null,
      "Time Zone": null,
      "Type": "xt2",
      "Updated": "2020-09-23T22:57:59+00:00",
      "Usage": null,
      "Usage Rate": "false",
      "Video Description": null,
      "Video History Count": null,
      "Video Length": null,
      "Video Quality": null,
      "Video Recording Optional": null,
      "WiFi Strength": "5",
      "WiFi Timeout": null,
      "battery": null,
      "temperature": "75"
    "commands": [
        "command": "Clear"
