OK! Thanks for the info, at least I know… All devices are Z-wave (7 Leviton DZPD3 dimmer modules, 1 Enbrighten Wall Dimmer), 1 Octan Remote, 2 Hank 4-button controllers… went through firmware upgrade on DZPD3’s with Aeotec Z-Stick from Leviton Tech Support… configured all using Ryan780’s Decora driver to “Lights turn on to:100”, 0 fade on/off, etc., then reset driver to “Generic Z-Wave Smart Dimmer”… The Hanks are controlling Lamps 5, 6, 7 just fine from RM…
Here is the current issue that’s causing a LOT more gray hair: I can’t seem to even get buttons 2 & 3 on the Octan to toggle. Button 1 works fine (I did an If-Then to toggle because it would return to whatever the last setting was):
Select Actions for Octan button 1 pushed, Toggle Lamp 4
IF (Dimmer level of Lamp 4(1) is <= 97(T) [TRUE]) THEN Dim: Lamp 4: 100 --> fade: 0 ELSE Dim: Lamp 4: 0 --> fade: 0 END-IF
Select Actions for Octan button 1 held, Start Lowering Lamp 4
Start lowering: Lamp 4
- Tried this code for buttons 2 & 3 for Lamp 3, didn’t work… then I tried just a regular toggle:
Select Actions for Octan button 3 pushed, Toggle Lamp 3
Toggle: Lamp 3
… which doesn’t work on either button… per the log below, nothing happens (including running the action from RM)… the light works fine from device screen…
dev:1642020-03-08 03:48:31.425 pm infoOctan Remote Button 3 pushed
- Log for Octan button 1 Lamp 4:
dev:2282020-03-08 03:48:26.308 pm infoLamp 4 is off [digital]
dev:2282020-03-08 03:48:26.109 pm infoLamp 4 was set to 1% [digital]
dev:2282020-03-08 03:48:26.100 pm infoLamp 4 is off [digital]
app:3282020-03-08 03:48:25.717 pm infoAction: END-IF
app:3282020-03-08 03:48:25.685 pm infoAction: Dim: Lamp 4: 0 --> fade: 0
app:3282020-03-08 03:48:25.679 pm infoAction: ELSE (do actions)
app:3282020-03-08 03:48:25.675 pm infoAction: Dim: Lamp 4: 100 --> fade: 0 (skipped)
app:3282020-03-08 03:48:25.668 pm infoAction: IF (Dimmer level of Lamp 4(99) is <= 97(F) [FALSE]) THEN (skipping)
app:3282020-03-08 03:48:25.604 pm infoOctan button 1 pushed, Toggle Lamp 4 Triggered
app:3282020-03-08 03:48:25.591 pm infoOctan button 1 pushed, Toggle Lamp 4: Octan Remote pushed 1
dev:1642020-03-08 03:48:25.440 pm infoOctan Remote Button 1 pushed
dev:2282020-03-08 03:48:22.644 pm infoLamp 4 is 99% [digital]
dev:2282020-03-08 03:48:22.639 pm infoLamp 4 is on [digital]
dev:2282020-03-08 03:48:22.434 pm infoLamp 4 was set to 99% [digital]
dev:2282020-03-08 03:48:22.429 pm infoLamp 4 was turned on [digital]
app:3282020-03-08 03:48:22.054 pm infoAction: END-IF
app:3282020-03-08 03:48:22.049 pm infoAction: Dim: Lamp 4: 0 --> fade: 0 (skipped)
app:3282020-03-08 03:48:22.042 pm infoAction: ELSE (skipping)
app:3282020-03-08 03:48:22.009 pm infoAction: Dim: Lamp 4: 100 --> fade: 0
app:3282020-03-08 03:48:22.002 pm infoAction: IF (Dimmer level of Lamp 4(1) is <= 97(T) [TRUE]) THEN
app:3282020-03-08 03:48:21.932 pm infoOctan button 1 pushed, Toggle Lamp 4 Triggered
app:3282020-03-08 03:48:21.918 pm infoOctan button 1 pushed, Toggle Lamp 4: Octan Remote pushed 1
dev:1642020-03-08 03:48:21.756 pm infoOctan Remote Button 1 pushed
--- Live Log Started, waiting for events ---
I ran the Exclude/Include on Lamp 3, rebuilt all the rules, and got exactly the same result… I am a bit mystified, would appreciate any help…
