I added a community driver to support my weather station, and am trying to turn off a light when the station reads an illuminance of greater than 600 using the Simple Lighting app. It never turns off the light. Looking at the log files for that rule, I see the following:
app:1962019-12-03 07:18:45.719 am errorjava.lang.NumberFormatException: For input string: "480.193" on line 426 (luxHandler)
app:1962019-12-03 07:13:46.271 am errorjava.lang.NumberFormatException: For input string: "216.657" on line 426 (luxHandler)
app:1962019-12-03 07:08:46.033 am errorjava.lang.NumberFormatException: For input string: "45.612" on line 426 (luxHandler)
app:1962019-12-03 07:03:45.929 am errorjava.lang.NumberFormatException: For input string: "0.0" on line 426
Does this look like a driver problem? The illuminance values seem OK when I click on Devices -> Weather Station.
Thanks! I am hoping to get a Simple Lighting rule to work. But if for some reason Simple Lighting is broken for illuminance, I'll try the same in Rule Machine.
I see in the developer API doc that Illuminance is a "number" - does that mean a long integer? Or would a floating point value be OK? (sorry the last language I programmed in was C - trying to help the driver's developer fix it quickly).
I'm sorry, I wish I could help more. I remembered this being an issue not too long ago with another API based weather driver. I'll see if I can find that discussion. BTW, the last language I programmed in was AppleBasic.
