Bingo - that's much more happier. Thank you!
@roberto, today I had the same error as you have, everything was working except the status update, The status was correct after a refresh.
This was the situation: I had a defect shelly, I replaced it with a new one with the original IP address, did a save settings and preference so the url's are saved to the shelly, everything was working except the status update.
After changing the IP address in the driver to another fictive one, save and then save the original one the problem of the status update was solved
Maybe this info can help somebody....
@BrunoVoeten ........ I want to buy you a beer!!!
I have been thrashing for a couple hours. Grrrrrrr
- New Shelly 2.5
- Updated the hub to the latest 2.3.1.139
- Updated the Shelly to the latest
- Uninstalled the 2.5 and reistalled, 4 times
- Cruising the community messages and stumbled here, thankfully
Your hints fixed it for me!!! My steps ...
- In the HE Devices flow, change the Shelly IP to something different
- Change the Shelly IP back to the original IP
- Now the "On" and "Off" buttons in the child devices work as expected, verified in the Shelly application
I did not alter the IP setting in the Shelly application when taking those steps. The device IP was not modified.
I no longer see the errors in the logs "no matching device found for ..."
Thanks again!!!
