Problems with room Lightning
I have been doing a lot of reading, however with no great success.
I want my lights on "vestterasse" "bedlampe 1-7" to start gradually from level 1 when illuminance is lower than 50. They can use 5000 seconds to turn on fully. It may not start if mode is Nat "night".
It turns on allright, and allso shuts down when mode is nat "night".
But the after a short time it turns on again, which I thought now was prevented. I am clearly doing something wrong, but what?
Allso, how bright will my bulbs be, 100?
What do the logs show when it it turns back on? This should tell us what is triggering it to turn on again. In case anyone is wondering I translated the other mode turning off (Væk) to Away which should not matter here.
This should be when it turns off
around 21:45 it starts again
Would be curious to see the Logs > location events to see the mode changes. I see app 2443 looks like it got triggered off twice so just wondering if something odd is going on with the modes. Also, looks like this was before you turned on debug logging? WOuld be good to see it again with debug logging enabled, also go to the mode manager app and turn on logging in there as well.
Also looks like you have a LOT of things triggering from those mode changes. You dont by chance have a duplicated RL setup for this room that is conflicting with the one shown?
I got four rules, which all act the same way, 2443 is one of them, therefore they are all paused.
About debug logging, it might well be so that I first activated it around that time.
I will activatew the one in question, and load a new log tomorrow.
I have a strange feeling about modes, I have changed all states into danish, however it seems to work. Also I am running with two hubs in my setup.
RL means??
RL means Room Lighting
For the modes, I found after renaming them it was needed to delete the mode manager app totally and reinstall it, setting it up again. Otherwise old stuff gets left over in there and can mess it up.
Rl thanks,
Maybe I should try to delete is totally and reinstall, I have seen odd things with the mode maneger.
I think that should be the next task, and when done, I will report back in here.
Thanks.
I did a rewrite on all my modes, and that seemed to dothe trick.
Thanks a lot for reaching out
