Problem with Quirky Overflow Driver with latest Homekit add
Continuing the discussion from Quirky Overflow Water Sensor:
I'm trying to get the Homekit app running with all my devices. After much experimentation and tweaking, I've got everything working
I am encountering some problems (but since I have a new C8, I have pretty much clean logs), I found that it seems that the Overflow sensors are generating a null pointer exception, which I believe then causes the Homebridge app to crash/hangup/not-respond-properly.
(I'm using : Quirky Overflow Water Sensor)
[dev:419](http://172.16.224.199/logs#)2023-04-10 07:18:54.364 PM[error](http://172.16.224.199/logs#)java.lang.NullPointerException: Cannot get property 'profileId' on null object on line 79 (method parse)
[dev:419](http://172.16.224.199/logs#)2023-04-10 07:18:53.376 PM[error](http://172.16.224.199/logs#)java.lang.NullPointerException: Cannot get property 'profileId' on null object on line 79 (method parse)
[dev:419](http://172.16.224.199/logs#)2023-04-10 07:18:52.911 PM[error](http://172.16.224.199/logs#)java.lang.NullPointerException: Cannot get property 'profileId' on null object on line 79 (method parse)
[dev:419](http://172.16.224.199/logs#)2023-04-10 07:18:51.875 PM[error](http://172.16.224.199/logs#)java.lang.NullPointerException: Cannot get property 'profileId' on null object on line 79 (method parse)
[sys:1](http://172.16.224.199/logs#)2023-04-10 07:18:51.134 PM[info](http://172.16.224.199/logs#)Zigbee Discovery Stopped
[dev:419](http://172.16.224.199/logs#)2023-04-10 07:18:50.805 PM[error](http://172.16.224.199/logs#)java.lang.NullPointerException: Cannot get property 'profileId' on null object on line 79 (method parse)
[dev:419](http://172.16.224.199/logs#)2023-04-10 07:18:50.395 PM[error](http://172.16.224.199/logs#)java.lang.NullPointerException: Cannot get property 'profileId' on null object on line 79 (method parse)
[sys:1](http://172.16.224.199/logs#)2023-04-10 07:18:50.247 PM[info](http://172.16.224.199/logs#)Created Zigbee Device Quirky Moisture Sensor
[sys:1](http://172.16.224.199/logs#)2023-04-10 07:18:48.798 PM[info](http://172.16.224.199/logs#)Initializing Zigbee Device 7CE5240000098FD5, 3AD7
[sys:1](http://172.16.224.199/logs#)2023-04-10 07:18:45.099 PM[info](http://172.16.224.199/logs#)Zigbee Discovery Running
That's the error section from the onboarding of one sensor until I received errors. Has anybody got the Overflow driver working on these sensors with the latest C8/firmware and Homekit app? (I had a similar issue with C7's so not sure it's anything particular to C8)
Is anybody doing updates to the Overflow Driver?
