How? The firmware version is not reported as a Z-wave parameter.
Give it a try, it works.
dev:491|2019-05-12 15:26:22.000|INFO|VersionReport- zWaveLibraryType:Enhanced Slave
dev:491|2019-05-12 15:26:22.002|INFO|VersionReport- zWaveProtocolVersion:4.33
dev:491|2019-05-12 15:26:22.003|INFO|VersionReport- applicationVersion:1.20
There is no GetVersionReport in the version I was using.
Seems that there was an update this past November. You know, some type of Github integration would have notified me about that!!! Sometimes I feel like I'm yelling into the wind.
Looks like mine is firmware v1.13.
But the driver I listed should fix the issue with the dimmer. I don't know if updated firmware would have any effect on the "on" command's behavior.
mine says this:
infoVersionReport- applicationVersion:1.13
I don't know if there's a way to get the latest version (1.20) and update the dimmer. They (Leviton) boast that the units are updatable OTA. But how?
Anyway, it seems that we have the same version. If yours works, mine should too. Now trying your driver... back in a sec.
ok I'm back. Tried the new driver. Wow! This one works!
Lots of settings... seems pretty cool!
Why is this driver not in the standard driver list??!!
Anyway, many thanks!
Well, for a few reasons. #1, this isn't an officially supported device. It's not on the list of supported devices. #2, the way that this device does fade-out is rather strange. It should not be setting the level to 0 and turning off. when it does it really has no choice but to go back to 100%. I will be cleaning up the driver and adding a disable for debugging (there's far too much in this driver) and taking out some of the things that are unnecessary for Hubitat. But you're very welcome.
I used Homeseer Z-flash to update mine. They did appear to work better with 1.2 but I forget now what the issues were precisely.
Use the following driver to configure any of the Leviton Z-Wave plus dimmer's firmware settings. It will also show you the FW version. What I usually do is use this driver for configuration and then switch back to the stock HE one.
* Copyright 2017 Jason Xia
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition (name: "Leviton Decora Z-Wave Plus Dimmer", namespace: "jasonxh", author: "Jason Xia", ocfDeviceType: "oic.d.light") {
capability "Actuator"
capability "Configuration"
capability "Health Check"
capability "Indicator"
capability "Light"
capability "Polling"
capability "Refresh"
capability "Sensor"
capability "Switch"
capability "Switch Level"
attribute "loadType", "enum", ["incandescent", "led", "cfl"]
attribute "presetLevel", "number"
attribute "minLevel", "number"
attribute "maxLevel", "number"
attribute "fadeOnTime", "number"
attribute "fadeOffTime", "number"
attribute "levelIndicatorTimeout", "number"
attribute "firmwareVersion", "string"
command "low"
command "medium"
command "high"
command "levelUp"
command "levelDown"
fingerprint mfr:"001D", prod:"3201", model:"0001", deviceJoinName: "Leviton Decora Z-Wave Plus 600W Dimmer"
fingerprint mfr:"001D", prod:"3301", model:"0001", deviceJoinName: "Leviton Decora Z-Wave Plus 1000W Dimmer"
preferences {
input name: "levelIncrement", type: "number", title: "In-App Level Increment",
description: "1 - 100 (default $defaultLevelIncrement)", range: "1..100", defaultValue: defaultLevelIncrement,
displayDuringSetup: false, required: false
input type: "paragraph", element: "paragraph", title: "Device Preferences",
description: "The following preferences are configuring the device behaviors. " +
"All of them are optional. Leave a preference empty to skip configuring it."
input name: "loadType", type: "enum", title: "Load type",
options: ["Incandescent (default)", "LED", "CFL"],
input name: "indicatorStatus", type: "enum", title: "Indicator LED is lit",
options: ["When switch is off (default)", "When switch is on", "Never"],
input name: "presetLevel", type: "number", title: "Light turns on to level",
description: "0 to 100 (default 0)", range: "0..100",
input type: "paragraph", element: "paragraph", title: "",
description: "0 = last dim level (default)\n1 - 100 = fixed level"
input name: "minLevel", type: "number", title: "Minimum light level",
description: "0 to 100 (default 10)", range: "0..100",
input name: "maxLevel", type: "number", title: "Maximum light level",
description: "0 to 100 (default 100)", range: "0..100",
input name: "fadeOnTime", type: "number", title: "Fade-on time",
description: "0 to 253 (default 2)", range: "0..253",
description: "0 = instant on\n1 - 127 = 1 - 127 seconds (default 2)\n128 - 253 = 1 - 126 minutes"
input name: "fadeOffTime", type: "number", title: "Fade-off time",
description: "0 = instant off\n1 - 127 = 1 - 127 seconds (default 2)\n128 - 253 = 1 - 126 minutes"
input name: "levelIndicatorTimeout", type: "number", title: "Dim level indicator timeout",
description: "0 to 255 (default 3)", range: "0..255",
description: "0 = dim level indicator off\n1 - 254 = timeout in seconds (default 3)\n255 = dim level indicator always on"
def installed() {
log.debug "installed..."
initialize()
response(refresh())
def updated() {
if (state.lastUpdatedAt != null && state.lastUpdatedAt >= now() - 1000) {
log.debug "ignoring double updated"
return
log.debug "updated..."
state.lastUpdatedAt = now()
initialize()
response(configure())
def configure() {
def commands = []
if (loadType != null) {
commands.addAll(setLoadType(loadType))
if (indicatorStatus != null) {
commands.addAll(setIndicatorStatus(indicatorStatus))
if (presetLevel != null) {
commands.addAll(setPresetLevel(presetLevel as short))
if (minLevel != null) {
commands.addAll(setMinLevel(minLevel as short))
if (maxLevel != null) {
commands.addAll(setMaxLevel(maxLevel as short))
if (fadeOnTime != null) {
commands.addAll(setFadeOnTime(fadeOnTime as short))
if (fadeOffTime != null) {
commands.addAll(setFadeOffTime(fadeOffTime as short))
if (levelIndicatorTimeout != null) {
commands.addAll(setLevelIndicatorTimeout(levelIndicatorTimeout as short))
log.debug "Configuring with commands $commands"
commands
def result = null
def cmd = zwave.parse(description, [0x20: 1, 0x25:1, 0x26: 1, 0x70: 1, 0x72: 2])
if (cmd) {
result = zwaveEvent(cmd)
log.debug "Parsed $cmd to $result"
} else {
log.debug "Non-parsed event: $description"
result
def on() {
def fadeOnTime = device.currentValue("fadeOnTime")
def presetLevel = device.currentValue("presetLevel")
short duration = fadeOnTime == null ? 255 : fadeOnTime
short level = presetLevel == null || presetLevel == 0 ? 0xFF : toZwaveLevel(presetLevel as short)
delayBetween([
zwave.switchMultilevelV2.switchMultilevelSet(value: level, dimmingDuration: duration).format(),
zwave.switchMultilevelV1.switchMultilevelGet().format()
], durationToSeconds(duration) * 1000 + commandDelayMs)
def off() {
def fadeOffTime = device.currentValue("fadeOffTime")
short duration = fadeOffTime == null ? 255 : fadeOffTime
delayBetween([
zwave.switchMultilevelV2.switchMultilevelSet(value: 0x00, dimmingDuration: duration).format(),
def setLevel(value, durationSeconds = null) {
log.debug "setLevel >> value: $value, durationSeconds: $durationSeconds"
short level = toDisplayLevel(value as short)
short dimmingDuration = durationSeconds == null ? 255 : secondsToDuration(durationSeconds as int)
sendEvent(name: "level", value: level, unit: "%")
sendEvent(name: "switch", value: level > 0 ? "on" : "off")
delayBetween([
zwave.switchMultilevelV2.switchMultilevelSet(value: toZwaveLevel(level), dimmingDuration: dimmingDuration).format(),
], durationToSeconds(dimmingDuration) * 1000 + commandDelayMs)
def poll() {
delayBetween(statusCommands, commandDelayMs)
def ping() {
poll()
def refresh() {
def commands = statusCommands
commands << zwave.versionV1.versionGet().format()
// if (getDataValue("MSR") == null) {
commands << zwave.manufacturerSpecificV1.manufacturerSpecificGet().format()
for (i in 1..8) {
commands << zwave.configurationV1.configurationGet(parameterNumber: i).format()
log.debug "Refreshing with commands $commands"
delayBetween(commands, commandDelayMs)
def indicatorNever() {
sendEvent(name: "indicatorStatus", value: "never")
configurationCommand(7, 0)
def indicatorWhenOff() {
sendEvent(name: "indicatorStatus", value: "when off")
configurationCommand(7, 255)
def indicatorWhenOn() {
sendEvent(name: "indicatorStatus", value: "when on")
configurationCommand(7, 254)
def low() {
setLevel(10)
def medium() {
setLevel(50)
def high() {
setLevel(100)
def levelUp() {
setLevel(device.currentValue("level") + (levelIncrement ?: defaultLevelIncrement))
def levelDown() {
setLevel(device.currentValue("level") - (levelIncrement ?: defaultLevelIncrement))
private static int getCommandDelayMs() { 1000 }
private static int getDefaultLevelIncrement() { 10 }
private initialize() {
// Device-Watch simply pings if no device events received for 32min(checkInterval)
sendEvent(name: "checkInterval", value: 2 * 15 * 60 + 2 * 60, displayed: false, data: [protocol: "zwave", hubHardwareId: device.hub.hardwareID, offlinePingable: "1"])
private zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd) {
dimmerEvent(cmd.value)
private zwaveEvent(hubitat.zwave.commands.switchmultilevelv1.SwitchMultilevelReport cmd) {
private zwaveEvent(hubitat.zwave.commands.switchmultilevelv1.SwitchMultilevelStopLevelChange cmd) {
response(zwave.switchMultilevelV1.switchMultilevelGet().format())
private zwaveEvent(hubitat.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
if (cmd.value == 0) {
switchEvent(false)
} else if (cmd.value == 255) {
switchEvent(true)
} else {
log.debug "Bad switch value $cmd.value"
private zwaveEvent(hubitat.zwave.commands.configurationv1.ConfigurationReport cmd) {
def result = null
switch (cmd.parameterNumber) {
case 1:
result = createEvent(name: "fadeOnTime", value: cmd.configurationValue[0])
break
case 2:
result = createEvent(name: "fadeOffTime", value: cmd.configurationValue[0])
break
case 3:
result = createEvent(name: "minLevel", value: cmd.configurationValue[0])
break
case 4:
result = createEvent(name: "maxLevel", value: cmd.configurationValue[0])
break
case 5:
result = createEvent(name: "presetLevel", value: cmd.configurationValue[0])
break
case 6:
result = createEvent(name: "levelIndicatorTimeout", value: cmd.configurationValue[0])
break
case 7:
def value = null
switch (cmd.configurationValue[0]) {
case 0: value = "never"; break
case 254: value = "when on"; break
case 255: value = "when off"; break
result = createEvent(name: "indicatorStatus", value: value)
break
case 8:
def value = null
case 0: value = "incandescent"; break
case 1: value = "led"; break
case 2: value = "cfl"; break
result = createEvent(name: "loadType", value: value)
break
result
private zwaveEvent(hubitat.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
log.debug "manufacturerId: $cmd.manufacturerId"
log.debug "manufacturerName: $cmd.manufacturerName"
log.debug "productId: $cmd.productId"
log.debug "productTypeId: $cmd.productTypeId"
def msr = String.format("%04X-%04X-%04X", cmd.manufacturerId, cmd.productTypeId, cmd.productId)
updateDataValue("MSR","")
updateDataValue("manufacturer","29")
createEvent([descriptionText: "$device.displayName MSR: $msr", isStateChange: false])
private zwaveEvent(hubitat.zwave.commands.hailv1.Hail cmd) {
createEvent(name: "hail", value: "hail", descriptionText: "Switch button was pressed", displayed: false)
private zwaveEvent(hubitat.zwave.commands.versionv1.VersionReport cmd) {
createEvent(name: "firmwareVersion", value: "${cmd.applicationVersion}.${cmd.applicationSubVersion}", displayed: false)
private zwaveEvent(hubitat.zwave.Command cmd) {
log.warn "Unhandled zwave command $cmd"
private dimmerEvent(short level) {
def result = null
if (level == 0) {
result = [createEvent(name: "level", value: 0, unit: "%"), switchEvent(false)]
} else if (level >= 1 && level <= 100) {
result = [createEvent(name: "level", value: toDisplayLevel(level), unit: "%")]
if (!isNewFirmware && device.currentValue("switch") != "on") {
// Don't blindly trust level. Explicitly request on/off status.
result << response(zwave.switchBinaryV1.switchBinaryGet().format())
} else {
result << switchEvent(true)
} else {
log.debug "Bad dimming level $level"
result
private switchEvent(boolean on) {
createEvent(name: "switch", value: on ? "on" : "off")
private getStatusCommands() {
def cmds = []
if (!isNewFirmware) {
// Even though SwitchBinary is not advertised by this device, it seems to be the only way to assess its true
// on/off status.
cmds << zwave.switchBinaryV1.switchBinaryGet().format()
cmds << zwave.switchMultilevelV1.switchMultilevelGet().format()
cmds
private short toDisplayLevel(short level) {
level = Math.max(0, Math.min(100, level))
(level == (short) 99) ? 100 : level
private short toZwaveLevel(short level) {
Math.max(0, Math.min(99, level))
private int durationToSeconds(short duration) {
if (duration >= 0 && duration <= 127) {
duration
} else if (duration >= 128 && duration <= 254) {
(duration - 127) * 60
} else if (duration == 255) {
2 // factory default
} else {
log.error "Bad duration $duration"
0
private short secondsToDuration(int seconds) {
if (seconds >= 0 && seconds <= 127) {
seconds
} else if (seconds >= 128 && seconds <= 127 * 60) {
127 + Math.round(seconds / 60)
} else {
log.error "Bad seconds $seconds"
255
private configurationCommand(param, value) {
param = param as short
value = value as short
delayBetween([
zwave.configurationV1.configurationSet(parameterNumber: param, configurationValue: [value]).format(),
zwave.configurationV1.configurationGet(parameterNumber: param).format()
], commandDelayMs)
private setFadeOnTime(short time) {
sendEvent(name: "fadeOnTime", value: time)
configurationCommand(1, time)
private setFadeOffTime(short time) {
sendEvent(name: "fadeOffTime", value: time)
configurationCommand(2, time)
private setMinLevel(short level) {
sendEvent(name: "minLevel", value: level)
configurationCommand(3, level)
private setMaxLevel(short level) {
sendEvent(name: "maxLevel", value: level)
configurationCommand(4, level)
private setPresetLevel(short level) {
sendEvent(name: "presetLevel", value: level)
configurationCommand(5, level)
private setLevelIndicatorTimeout(short timeout) {
sendEvent(name: "levelIndicatorTimeout", value: timeout)
configurationCommand(6, timeout)
private setLoadType(String loadType) {
switch (loadType) {
case "Incandescent (default)":
sendEvent(name: "loadType", value: "incandescent")
return configurationCommand(8, 0)
case "LED":
sendEvent(name: "loadType", value: "led")
return configurationCommand(8, 1)
case "CFL":
sendEvent(name: "loadType", value: "cfl")
return configurationCommand(8, 2)
private setIndicatorStatus(String status) {
switch (indicatorStatus) {
case "When switch is off (default)": return indicatorWhenOff()
case "When switch is on": return indicatorWhenOn()
case "Never": return indicatorNever()
private boolean getIsNewFirmware() { device.currentValue("firmwareVersion") ==~ /1\.2\d/ }
I've been banging my head against a wall with exactly this same problem for days now, and decided to google it and found this thread. These new drivers work perfectly!
Thanks to all who contributed and posted.
Hi, I'm using the driver listed in post 28 and now the status changes properly in the dashboard with this Leviton dimmer. However, I can't seem to figure out how to determine the FW version of the dimmer.
Just a noob here, on my first day loading my devices and I've got one of these. Lots of problems with it that look to all have gone away when I loaded the HE "Generic CentralScene Dimmer" driver.
Nice. I’ll have to try that out!
Just found this thread as I was having issues similar to the OP. The "Generic Z-wave CentralScene Dimmer" driver did the trick for me!
These drivers worked for me as well.
I have Leviton dimmer plug DZPD3, and have used the driver recommended in this thread. My issue is that the max brightness seems not to change above 50%. Stepping up (by pressing level Up button) works nicely from 0-50% and than while the level keeps increasing all the way to 100% the actual brightness of the lights does not change. When I plug the lamp directly to outlet its noticeably brighter.
Not sure if related, but I have another observation. When the device is discovered by the hub its picked up as "Generic Z-Wave CentralScene Dimmer". I have to manually change the type to "Leviton Decora Z-Wave Plus Dimmer" (via Type dropdown in Device Information section). Once the type is changed I can see all the additional config options provided by the driver, but the device metadata does not report as @Ryan780 shared. My device data is as folllowing:
- deviceType: 13569
- inClusters: 0x5E,0x85,0x59,0x86,0x72,0x70,0x5A,0x73,0x26,0x20,0x27,0x2C,0x2B,0x7A
- outClusters: 0x82
- deviceId: 1
- MSR:
- manufacturer: 29
What load type do you have the device set for? What type of bulb do you have in the lamp?
I have the exact same and I've had to stick with the custom driver to get around the 50% problem. It's been working as one would expect for many weeks now. The "Generic Z-Wave CentralScene Dimmer" is a terrible match for the DZPD3. My Load Type is LED and so is the bulb.
Load Type = LED. Bulb is LED and also tested with LED strip.
LED strips? They won't work with this dimmer. This dimmer is for 120 VAC. LED strips are usually 5-24v DC. So, I'm not sure why you'd hook them to this dimmer. You can't dim LED strips with a mains dimmer.
Is the LED you are using dimmable?
@Ryan780 thank you for good suggestions, that made me rethink my implementation. In summary, the DZPD3 appears to work fine with HE and the driver I described in this post. It helps to confirm that the LED bulb is dimmable, This was my issue while bulb, and while it would respond to lower voltage it was no dimming as expected.
