Mine is slight different. (MSR and device id if that matter)
I have several of these plugs, both new and old, and interestingly enough none of them has an MSR entry. I wonder what that means ?
Let me add.. My newest plug actually shows Kwh, but my older ones donΒ΄t.
Here is an old one:
And here is a new one:
Hello Fibaro EU Plug Owners,
I noticed that power reporting started to work for my Fibaro EU Plug!
Seems it is the result of recent update of HE firmware to 2.1.5 (though I have to admit that I was losing hope and was not checking thie plug after few previous updates).
Did it start to work for you as well?
Late reply, but yes! Working for me as well. Thank you, Team Hubitat! <3
Hi
I have the UK Fibaro Wall Plug and I am getting energy and power reported correctly which is good. Using the resetPower I can successfully set the power back to zero but resetEnergy doesn't error or do anything so far as I can see.
Anyone else got the same issue?
I found this message as I'm having this issue for a European Wall Plug too: no power reporting. Using the default driver.
Any ideas?
Same for me here in EU/DE:
|Controller Type|ZWV|
|Data|* deviceType: 1536
- inClusters: 0x72,0x86,0x70,0x85,0x8E,0x25,0x73,0x32,0x31,0x7A
- zwNodeInfo: D3 9C 00 04 10 00
- outClusters: 0x25,0x32,0x31
- deviceId: 4096
- MSR: 010F-0600-1000
- manufacturer: 271|
Any comments on this?
/Oliver
I can now comment on this by my own. I fixed the issue for myself by changing the driver for the " Fibaro Wall Plug", FGWPF-101 to the driver "Aeotec Smart Energy Switch". Now the show up with the states:
#### Current States
* energy : **1.91**
* power : **0.0**
* powerH : **0**
* powerL : **0**
* switch : **on**
Only power gives valid values, energy not.
