Yesterday I upgraded from v2.0.8 to v2.0.9. Last night 2 of my Leviton Dimmer Plugs stopped working (Model VRPD3). Today I excluded one and reincluded it, and it is now recoginized as a "Fan"; yesterday it was a "Fan Controller". However, it still does not work.
I've just moved over from Wink and would appreciate any help in getting these devices working again.
Thanks,
Ted
Go to the device page and click on that device to edit its properties. About 1/2 way down the device detail page will an option for type. Change that to match what your device is. I'm not sure if there is a specific driver/type for the Leviton dimmer plug. If there isn't, then there should be a "generic" driver/type you can use. A vast majority of devices will use a "generic" driver.
That did it. Thanks.
I had the same problem. When I moved from Wink about 2 months ago they worked fine even though described as fan control. I went to device detail and changed them to "Generic Z-Wave Dimmer". everything back up and running.
