Problem sys:1 warning after removing Maker API instance
I removed a Maker API instance and now there is a sys:1 warning.
Perhaps I didn't properly remove the Maker API instance. Something is still responding to the remote device. I have deleted the Maker API instance and the corresponding device driver. I need help fixing the warning.
Not an issue with your hub so much as an issue with an external application trying to set a temperature on it. What application(s) were you using to set a temperature on device 6153?
Thank you, that's what I needed to have the light come on. The external application is still configured to point to this hub instead of the hub I moved it to. Still a noobie when comes to all the moving parts of Maker Api.
