One sensor of a group of 10 identical Iris V1 sensors refuses to stay connected, despite all of them sitting in a row, yet to be deployed. When re-discovering the sensor, Hubitat gets no further than "Found Previously Joined Device". The sensor keeps flashing, as if it is still trying to pair.
The logs are below. Is there a more detailed technical guide to address the detailed logs anywhere?
sys:12020-05-17 07:04:31.000 am infoIris Discovery Stopped
dev:972020-05-17 07:04:24.513 am infoskipped: cluster:0006, [raw:catchall: 0000 0006 00 00 0040 00 13CB 00 00 0000 00 00 03FDFF16C20001F000, profileId:0000, clusterId:0006, clusterInt:6, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:13CB, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[03, FD, FF, 16, C2, 00, 01, F0, 00]]
dev:972020-05-17 07:04:24.509 am debugparse: catchall: 0000 0006 00 00 0040 00 13CB 00 00 0000 00 00 03FDFF16C20001F000
dev:972020-05-17 07:04:24.507 am infoskipped: cluster:0013, [raw:catchall: 0000 0013 00 00 0040 00 13CB 00 00 0000 00 00 83CB1376B0B103006F0D0080, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:13CB, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[83, CB, 13, 76, B0, B1, 03, 00, 6F, 0D, 00, 80]]
dev:972020-05-17 07:04:24.494 am debugparse: catchall: 0000 0013 00 00 0040 00 13CB 00 00 0000 00 00 83CB1376B0B103006F0D0080
sys:12020-05-17 07:04:23.889 am infoFound Previously Joined Zigbee Device Iris V1 B076
dev:972020-05-17 07:04:23.866 am warnconfigure...
dev:1092020-05-17 07:04:14.450 am infoiris V1 9B69 adjusted temperature is 72.50Ā°F [sensor value 72.50]
dev:972020-05-17 07:04:09.410 am infoskipped: cluster:0006, [raw:catchall: 0000 0006 00 00 0040 00 F8B4 00 00 0000 00 00 02FDFF16C20001F000, profileId:0000, clusterId:0006, clusterInt:6, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:F8B4, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[02, FD, FF, 16, C2, 00, 01, F0, 00]]
dev:972020-05-17 07:04:09.407 am infoskipped: cluster:0013, [raw:catchall: 0000 0013 00 00 0040 00 F8B4 00 00 0000 00 00 82B4F876B0B103006F0D0080, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:F8B4, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[82, B4, F8, 76, B0, B1, 03, 00, 6F, 0D, 00, 80]]
dev:972020-05-17 07:04:09.404 am debugparse: catchall: 0000 0006 00 00 0040 00 F8B4 00 00 0000 00 00 02FDFF16C20001F000
dev:972020-05-17 07:04:09.400 am debugparse: catchall: 0000 0013 00 00 0040 00 F8B4 00 00 0000 00 00 82B4F876B0B103006F0D0080
sys:12020-05-17 07:04:08.785 am infoFound Previously Joined Zigbee Device Iris V1 B076
dev:972020-05-17 07:04:08.769 am warnconfigure...
dev:972020-05-17 07:03:49.640 am infoskipped: cluster:00F6, [raw:catchall: C216 00F6 02 02 0040 00 89B6 01 00 0000 FD 01 00FF, profileId:C216, clusterId:00F6, clusterInt:246, sourceEndpoint:02, destinationEndpoint:02, options:0040, messageType:00, dni:89B6, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:FD, direction:01, data:[00, FF]]
dev:972020-05-17 07:03:49.633 am debugparse: catchall: C216 00F6 02 02 0040 00 89B6 01 00 0000 FD 01 00FF
dev:972020-05-17 07:03:44.318 am infoskipped: cluster:0013, [raw:catchall: 0000 0013 00 00 0040 00 89B6 00 00 0000 00 00 81B68976B0B103006F0D0080, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:89B6, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[81, B6, 89, 76, B0, B1, 03, 00, 6F, 0D, 00, 80]]
dev:972020-05-17 07:03:44.316 am infoskipped: cluster:0006, [raw:catchall: 0000 0006 00 00 0040 00 89B6 00 00 0000 00 00 01FDFF16C20001F000, profileId:0000, clusterId:0006, clusterInt:6, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:89B6, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[01, FD, FF, 16, C2, 00, 01, F0, 00]]
dev:972020-05-17 07:03:44.313 am debugparse: catchall: 0000 0006 00 00 0040 00 89B6 00 00 0000 00 00 01FDFF16C20001F000
dev:972020-05-17 07:03:44.306 am debugparse: catchall: 0000 0013 00 00 0040 00 89B6 00 00 0000 00 00 81B68976B0B103006F0D0080
sys:12020-05-17 07:03:43.524 am infoFound Previously Joined Zigbee Device Iris V1 B076
dev:972020-05-17 07:03:43.493 am warnconfigure...
sys:12020-05-17 07:03:31.039 am infoIris Discovery Running
