Problem identifying device for driver pairing
I am running a c-7 on latest firmware.
The device auto identified as device. Clicked get info and went to log
2025-02-05 11:35:52.977 PM
info
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0001,0020,0402,0405", outClusters:"0019", model:"TH01", manufacturer:"eWeLink", controllerType: "ZGB"
Application 71
In Clusters 0000,0003,0001,0020,0402,0405
Manufacturer eWeLink
Model TH01
Out Clusters 0019
Software Build 0122052017
Thanks.
You need to manually change the driver. Under Device Info - Type. This looks to be the Sonoff Temp/Humidity sensor? There is a Sonoff driver you can select for that.
Once you change the Type dropdown, go back to commands tab and press configure.
You can also use this driver if you want to be able to change how often it reports.
Some devices may not have an official driver, then "Device" is selected by default.
If you try it out and it works with one of the built in drivers, post which one it works with and staff can add the fingerprint to it for future users.
Well, it does look like it is working now. I used the tuya 4 in 1 driver.
Here is the info to add.
Application 46
Manufacturer _TZ3000_lf56vpxj
Model TS0202
Tuya Version 1.0.6
Yep, it is working reliably so far with the 4 in 1 driver with battery, humidity, and temperature.
These temp-humid sensors were purchased through AliExpress.
Thanks for the assistance.
Paul
