Primer: What App to use for What?
I thought I'd describe each of the HE apps using a simple use case phrase that describes when you'd be likely to use each app. What do you all think of the wording? I know it's overly simplified, but I was thinking about how I choose an App for a given automation.
  • Basic Rules - When this happens, do the following steps.
  • Simple Automation Rules - When this happens, do this thing.
  • Room Lighting - When this happens, control the state of lights/devices of a single room, or across multiple rooms.
  • Rule Machine - When this happens, and the conditions are right, do a bunch of custom actions/changes, or do other things if something else is right/wrong.
  • Button Controller - When a button is pressed, double pressed, held or released do a bunch of custom things conditionally or immediately similar to Rule Machine.
  • Notifications - When a sensor detects this, send a message to this
  • Hubitat Safety Manager - When a sensor detects this, send an alert message or trigger an alarm if the Hubitat Safety Manager is alarmed for that thing.
  • Mode Manager - When this time or presence happens, set Hubitat's mode to this.
What simple phrases sum up the apps for you?
RM - makes magic happen :grin:
I don't know... Room Lighting can make some magic happen... depending on the room. nudge nudge wink wink
