Presence Sensors and Automated Backups
Hi,
I seem to have an issue with my presence sensor is leaving my Geo-fense when my system does an automated backup. For the past few weeks I couldn't figure out why my sensor would leave around 3 am every few days. Until i did a manual backup and notice my presence sensor left and returned. I then went back and checked my logs and it seems to coincide with the scheduled backups now things make sense. Is there anything I can do to solve this issue? I had to go back and change my rule machine rules so that my doors don't unlock in the middle of the night.
-D
Just to clarify, is this a presence sensor fob (i.e. a physical device) or your phone with the hubitat mobile app as a presence device?
Yes it's the Smartthings Presence Sensor.
Just checked mine and I am not seeing that.
It might be how they are connected through a router device causing it.
Mine are set to timeout at the lowest set point of 2 minutes.
Does your backup take longer than 2 minutes?
the SmartThings presence sensors report every 20 seconds so as long as your backup is complete in less than 2-3 minutes it should not go departed.
or the router it is going through is not reporting often enough.
check you route info
https://"hub ip"/hub/zigbee/getChildAndRouteInfo
Also are you using the Stock DH "SmartThings presence sensor V4"?
It took 2mins and 20 seconds and my device departed right after it finished the backup and i clicked the download button.
try setting the SmartThings presence sensor depart time to longer than 2 minutes and see if that fixes it.
seems a bit long to create a back up but if you have your hub loaded up with custom apps and devices that could be you issue not really a SmartThings presence sensor issue but a slow hub issue.
derge,
I am having the same issue! 3:05 AM... Then my wife (my customer in this effort) tells me when she comes downstairs in the morning, all the LIGHTS ARE ON! Not Happy.
Guess I will try the timeout setting.
try using the Xbee3 presence sensor DH it will work with SmartThings arrival/presence sensors and you can set to 10 minutes sometimes the 5 minutes with the stock SmartThings DH will not be enough.
My stock DH goes up to 15 mins
Didn't notice Hubitat updated the stock SmartThings presence DH with 10 & 15 minute haven't used them in so long.
