I got my first failure for life 360 last night. Garage opened for no reason while I was home. Is there a way to set the rule up to where it will only activate if I've been gone for a specified amount of time?
Sure. In the actions for your rule you can use "Delay these actions with cancel". You choose how long to delay. The cancel deals with false not-present events, in that if you are sensed as not present, and then become present before the delay period runs out, the whole thing is cancelled.
Is that what you're looking for?
yes. where would that go in exactly?
If you have Actions for True, it is the first option (same for Actions for False). It depends on how you have your rule setup,
