@aaiyar Got it. I have setup the virtual presence devices.
My other guess would be the Departure / Arrival Threshold would be now many Sensors have to be set to Arrive or Not Present before it will trigger the Virtual Device.
No signature of method: Script1.definition() is applicable for argument types: (java.util.LinkedHashMap) values: [[name:Presence Governor - Child, namespace:dwb, parent:dwb:Presence Governor, ...]]
I tried that also.. I get this error message.
No signature of method: Script1.definition() is applicable for argument types: (java.util.LinkedHashMap) values: [[name:Presence Governor, namespace:dwb, author:Doug Beard, description:Combine the states of multiple presence sensors into a single proxy state., ...]]
I can't seem to get PG to work. I'm using Iphone (Hubitat App) and WiFi. Settings Questions: What goes into Presence Section? (I Put my Iphone) What goes into Proxy Section? (I put in Virtual Devices) Doing it this way never shows mine or my wife's phone as away. Any help is appreciated. EDIT: WiFi driver is installed
You need to create a virtual presence device to be your proxy. The app will set the virtual device present or not based on the combination and thresholds you set. Then use your virtual presence proxy for automations based on presence.
I always meant to add the proxy creation automation during app installation but haven’t gotten to it.
So might be a strange question, I have a Zigbee Kwikset lock. When I set the lock, it does not let me select the master code? is there a way to get that to be one of the codes that unset the presence.
If the master code wasn't set using Hubitat, then Hubitat would be unaware of it. When I've setup my locks using Hubitat, I factory reset them, then deleted the two "factory" codes in slot 1 and slot 2 before adding new codes using Lock Code Manager.
I only have one presence sensor per person, the Hubitat app for both myself and my wife. To that we have one keyfob each and Wifi detection, but those are in separate menus.
I have the thresholds set to 1/1 (as we only have.. well, one), and a few minutes ago when I went down to the basement my virtual presence triggered me as away. The state at that time was Hubitat app present, Wifi not present and keyfob not present. My desired outcome in that case is "do nothing", as I'm in fact still "home".
Am I understanding the thresholds wrong? I think of them as "number of devices that has to register as present/not present", and in that case I thought 1/1 would be the correct setup.
The threshold applies only to those presence devices in the Presence Sensors list. Each different presence detection type has a different algorithm for setting your presence.
