I'm trying to use RM to fire At Home Simulator when mode is Away AND mode is Evening OR Night.
I can only see how to use ANY
Use Mode Manager to set mode to Away when all leave. Then you can have a rule that fires on mode becomes Away...
There can be only one mode at a time, so you can't have mode Away AND Evening.
Thanks bravenel.
Can you suggest the best approach to use Time and Presence together?
Trigger would be time
Then action
If mode away then turn on virtual switch to control simulator
