jatgm1
February 21, 2020, 9:41pm
1
Are there any devices that can detect weather or not power is coming from a 110v outlet and act as a trigger like this device I found? Or a smart multimeter? That works too I think.
So I can have hubitat kill everything not-essential if the power goes out to keep the UPS es going longer
JBrown
February 21, 2020, 9:46pm
2
This may give you some ideas.
In a few weeks I am having a sump pump installed in my crawl space because of on going water issues. I have a receptacle in the area of the pump that is tied into a GFIC outlet. For obvious reasons I want to be notified if this outlet ever loses power.
I saw @Cobra and @Navat604 old posts on the ST community
Curious if these solutions are still working or if there are better ideas.
@Navat604 what relay did you use in your contact sensor? It is very small and appears like you have it in…
This is what I use.
I used a Monoprice Contact Sensor KFR-ZD2105US-5, 2N2222 transistor, 220 ohm resistor and a old USB cord. It uses less current than a relay.
[image] [image] [image]
jatgm1
February 21, 2020, 10:22pm
3
Wireless Z-Wave Multi-Input/Output Dry Contact Bridge; Cert ID: ZC08-16040002 https://smile.amazon.com/dp/B00B6RZ7MM/ref=cm_sw_r_cp_apa_i_wEfuEbGA5VNWT
Anyone know if there's a driver for this? I imagine I can just put a 12v adapter into the input for the sensor and if the power goes out it'll report no power right?
njanda
February 22, 2020, 2:04am
4
Just be sure you’re aware OK with that device as it looks to be Zwave NOT “ZwavePlus”.
jatgm1
February 22, 2020, 3:49pm
5
as far as response time isnt it the same?
njanda
February 25, 2020, 4:55am
6
These links outline the benefits of ‘plus’ which should be faster.
https://inovelli.com/z-wave-home-automation/z-wave-plus/#Z-Wave%20Plus%20Benefits
OR
Z-wave plus is the newest generation (2015) in zwave. It is also called fifth generation, or gen five, Z-wave. Lots of improvements. The zwave piece itself is smaller, which means sensors and other devices including it can be smaller, and it...
Reading time: 2 mins 🕑
Likes: 5 ❤
system
Closed
September 22, 2022, 5:48pm
7
