Hi,
I just bought a new device, a Ledvance Smart+ Zigbee outlet.
I realize this device might not be supported yet but here goes.
It was recognized by HE as a Generic Zigbee Outlet.
In the Device Details it now seems to be recorded as a "Plug 01" device by Osram.
It seems to be able to report power but it only reported it once when I tested it, that is the power went up to 30 W and stayed there even after the connected appliance (a washing machine) was turned off.
Does it need a dedicated driver in order to properly report Power?
Hi BIGs,
thanks for your input - it may be that I was expecting too much.
Odd that it reported wattage when the washing machine powered up though, even if it also did not report further changes. Almost as though it has the capability but that it has not been implemented fully.
Do you know of a recommended smart plug that reports power and is proven to work with Hubitat?
Iris 3210-L2 report power. They're zigbee with a zwave repeater also and can usually find them for around 5 bucks. I wouldn't use the zwave side though it can cause more problems than help. The 3210-L will do the same thing if you see those also.
I have several that I had on my SmartThings and on that platform I had power consumption. On Hubitat there is no driver for them to report power consumption.
I just got the UK version and it's only picked up as a Zigbee device. Someone on Amazon mentioned using the Nue switch driver but that didn't work for me on a C7 hub.
