Is anyone using HE data to graph power consumption? If so, what are you using and how do you set it up? I want to see what a device is using over time.
WOW! influx is way too expensive!
Ummmm, itβs free to run on your own local server
How are you exporting data?
I donβt see that on their website.
Then I missed something. I see their website, $249 a month. Higher if you want to use their cloudserver. Nowhere does it say free, other than 15 day free trial.
Please post a link where it can be used for free on your own local server.
Are you using separate HEMs for all those in HE?
Multiple HEM's, Iris/ST outlets, Aotec Smart Plugs and strips. Most are still on ST as HE really doesn't like smoothly reporting power from most of them.
I use "to the second" power reports for a lot of automations, so I still have a lot of cross integration with ST and HE.
Take a look here for instruction. Some of us already ported the smartapp over to HE but it's not 100% but functional for data logging. Just don't enable logging of hub properties and you'll be fine.
I supposed you were using something else because me with one HEM in HE means trouble...
Thanks for the info.
I would like this functionality, but unfortunately it looks too complicated for my experience.
Not being able to see the "free to run on your own local server" plainly is by design. They want you to buy things so they can stay in business. But a single-node instance of influxdb can definitely be used for free.
The link that @ogiewon posted earlier is what you want. Click on the "v.1.6.3":
You'll see a bunch of different options for how you can run it depending on your platform.
What driver do you use for your HEM in HE?
I'm using this driver.
* Aeon HEM1
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Aeon Home Energy Meter v1 (US)
metadata {
definition (name: "My Aeon Home Energy Monitor v3", namespace: "jscgs350", author: "SmartThings")
capability "Energy Meter"
capability "Power Meter"
capability "Configuration"
capability "Sensor"
capability "Refresh"
capability "Polling"
capability "Battery"
attribute "energy", "string"
attribute "energyDisp", "string"
attribute "energyOne", "string"
attribute "energyTwo", "string"
attribute "power", "string"
attribute "powerDisp", "string"
attribute "powerOne", "string"
attribute "powerTwo", "string"
command "reset"
command "configure"
command "resetmaxmin"
fingerprint deviceId: "0x2101", inClusters: " 0x70,0x31,0x72,0x86,0x32,0x80,0x85,0x60"
preferences {
input "kWhCost", "string", title: "\$/kWh (0.16)", defaultValue: "0.16" as String, displayDuringSetup: true
//log.debug "Parse received ${description}"
def result = []
//log.debug "desc: ${description}"
def cmd = zwave.parse(description, [0x31: 1, 0x32: 1, 0x60: 3])
if (cmd) {
result << createEvent(zwaveEvent(cmd))
//if (result) log.debug "Parse returned ${result}"
def statusTextmsg = ""
statusTextmsg = "Min was ${device.currentState('powerOne')?.value}\nMax was ${device.currentState('powerTwo')?.value}"
sendEvent("name":"statusText", "value":statusTextmsg)
//log.debug statusTextmsg
return result
def zwaveEvent(hubitat.zwave.commands.meterv1.MeterReport cmd) {
//log.debug "zwaveEvent received ${cmd} ${cmd.payload} ${cmd.format()}"
def dispValue
def newValue
def timeString = new Date().format("yyyy-MM-dd h:mm a", location.timeZone)
if (cmd.meterType == 33) {
if (cmd.scale == 0) {
newValue = cmd.scaledMeterValue
log.debug state
if (newValue != state.energyValue) {
dispValue = String.format("%5.2f",newValue)+"\nkWh"
sendEvent(name: "energyDisp", value: dispValue as String, unit: "")
state.energyValue = newValue
BigDecimal costDecimal = newValue * ( kWhCost as BigDecimal)
def costDisplay = String.format("%3.2f",costDecimal)
sendEvent(name: "energyTwo", value: "Cost\n\$${costDisplay}", unit: "")
[name: "energy", value: newValue, unit: "kWh"]
} else if (cmd.scale == 1) {
dispValue = String.format("%5.2f",newValue)+"\nkVAh"
[name: "energy", value: newValue, unit: "kVAh"]
else if (cmd.scale==2) {
newValue = Math.round( cmd.scaledMeterValue ) // really not worth the hassle to show decimals for Watts
if (newValue != state.powerValue) {
dispValue = newValue+"w"
sendEvent(name: "powerDisp", value: dispValue as String, unit: "")
if (newValue < state.powerLow) {
dispValue = newValue+"w"+" on "+timeString
sendEvent(name: "powerOne", value: dispValue as String, unit: "")
state.powerLow = newValue
if (newValue > state.powerHigh) {
sendEvent(name: "powerTwo", value: dispValue as String, unit: "")
state.powerHigh = newValue
state.powerValue = newValue
[name: "power", value: newValue, unit: "W"]
def zwaveEvent(hubitat.zwave.commands.batteryv1.BatteryReport cmd) {
def map = [:]
map.name = "battery"
map.unit = "%"
if (cmd.batteryLevel == 0xFF) {
map.value = 1
map.descriptionText = "${device.displayName} has a low battery"
map.isStateChange = true
} else {
map.value = cmd.batteryLevel
//log.debug map
return map
def zwaveEvent(hubitat.zwave.Command cmd) {
// Handles all Z-Wave commands we aren't interested in
log.debug "Unhandled event ${cmd}"
def refresh() {
log.debug "Refreshed ${device.name}"
def cmds = delayBetween([
zwave.meterV2.meterGet(scale: 0).format(),
zwave.meterV2.meterGet(scale: 2).format()
log.debug "refresh cmds ${cmds}"
cmds
def poll() {
refresh()
def reset() {
log.debug "${device.name} reset kWh/Cost values"
state.powerHigh = 0
state.powerLow = 99999
sendEvent(name: "energyOne", value: "Energy Data (kWh/Cost) Reset On:\n"+timeString, unit: "")
sendEvent(name: "energyDisp", value: "", unit: "")
sendEvent(name: "energyTwo", value: "Cost\n--", unit: "")
def cmd = delayBetween( [
zwave.meterV2.meterReset().format(),
cmd
def resetmaxmin() {
log.debug "${device.name} reset max/min values"
state.powerHigh = 0
sendEvent(name: "energyOne", value: "Watts Data (min/max) Reset On:\n"+timeString, unit: "")
sendEvent(name: "powerOne", value: "", unit: "")
sendEvent(name: "powerTwo", value: "", unit: "")
cmd
def configure() {
log.debug "${device.name} configuring device"
def cmd = delayBetween([
//zwave.configurationV1.configurationSet(parameterNumber: 255, size: 4, scaledConfigurationValue: 1).format() // Performs a complete factory reset. Use this all by itself and comment out all others below. Once reset, comment this line out and uncomment the others to go back to normal
zwave.configurationV1.configurationSet(parameterNumber: 3, size: 1, scaledConfigurationValue: 1).format(), // Disable selective reporting, so always update based on schedule below <set to 1 to reduce network traffic>
zwave.configurationV1.configurationSet(parameterNumber: 4, size: 2, scaledConfigurationValue: 50).format(), // (DISABLED by first option) Don't send unless watts have changed by 25 <default is 50>
zwave.configurationV1.configurationSet(parameterNumber: 8, size: 1, scaledConfigurationValue: 10).format(), // (DISABLED by first option) Or by 5% <default is 10>
zwave.configurationV1.configurationSet(parameterNumber: 101, size: 4, scaledConfigurationValue: 4).format(), // Combined energy in Watts
zwave.configurationV1.configurationSet(parameterNumber: 111, size: 4, scaledConfigurationValue: 30).format(), // Every 60 Seconds (for Watts)
zwave.configurationV1.configurationSet(parameterNumber: 102, size: 4, scaledConfigurationValue: 8).format(), // Combined energy in kWh
zwave.configurationV1.configurationSet(parameterNumber: 112, size: 4, scaledConfigurationValue: 60).format(), // every 5 minutes (for kWh)
zwave.configurationV1.configurationSet(parameterNumber: 103, size: 4, scaledConfigurationValue: 0).format(), // Disable report 3
zwave.configurationV1.configurationSet(parameterNumber: 113, size: 4, scaledConfigurationValue: 0).format() // Disable report 3
cmd
I haven't seen this version of the driver yet. I tried it but don't get the updates as the config shows, or I'm reading it wrong. The value for watts is 30 seconds (vs 60 in comment) and 60 seconds for energy (vs 5 min in comments). Is a factory reset with the commented out line necessary to get it working right? I'm having well over a few minutes between watt updates.
I am not sure. How are you powering it? I am using USB power. I am getting a reading every minute.
dev:5252018-09-22 08:33:05.476:debug[powerLow:-1840644, powerValue:1551, powerHigh:1484259, energyValue:1527.933]
dev:5252018-09-22 08:32:05.455:debug[powerLow:-1840644, powerValue:1551, powerHigh:1484259, energyValue:1527.912]
dev:5252018-09-22 08:31:05.446:debug[powerLow:-1840644, powerValue:1551, powerHigh:1484259, energyValue:1527.885]
dev:5252018-09-22 08:30:05.436:debug[powerLow:-1840644, powerValue:1551, powerHigh:1484259, energyValue:1527.858]
USB as well. One of my HEM's reports roughly every minute even though it's set to 15 seconds, my primary just never is consistent. I've physically reset and re-added a number of times. I have about 4-5 paired to HE right now, very strong mesh in that area as well.
Here's what I see with the built in HEM driver:
| power | 350 | W | DEVICE | 2018-09-22 9:45:07.543 AM MDT | ||
| energy | 510.555 | kWh | DEVICE | 2018-09-22 9:44:37.544 AM MDT | ||
| power | 304 | W | DEVICE | 2018-09-22 9:40:07.505 AM MDT | ||
| energy | 510.531 | kWh | DEVICE | 2018-09-22 9:39:37.573 AM MDT | ||
| power | 329 | W | DEVICE | 2018-09-22 9:35:07.470 AM MDT | ||
| power | 272 | W | DEVICE | 2018-09-22 9:30:07.445 AM MDT | ||
| energy | 510.481 | kWh | DEVICE | 2018-09-22 9:29:37.445 AM MDT | ||
| power | 294 | W | DEVICE | 2018-09-22 9:25:07.409 AM MDT | ||
| energy | 510.456 | kWh | DEVICE | 2018-09-22 9:24:37.410 AM MDT | ||
| energy | 510.316 | kWh | DEVICE | 2018-09-22 8:54:37.201 AM MDT |
And the version of the driver you use after a full reset, no updates since I captured this:
dev:5542018-09-22 09:46:40.728:debug[powerLow:99999, powerValue:1572, powerHigh:0, energyValue:0.002]
dev:5542018-09-22 09:46:40.546:debugEnergy Meter reset max/min values
dev:5542018-09-22 09:46:39.654:debugEnergy Meter reset kWh/Cost values
dev:5542018-09-22 09:46:17.482:debugEnergy Meter configuring device
