Power adapter with longer cord
Is there a power adapter with a longer cord that can be used with the hub? If so, can I get a part number or a link to a place to purchase one? The one that came with the hub is too short for me.
USA?
UK?
Europe?
How long does it need to be?
USA. 6+ feet.
Amazon.com has extension leads...
Iā€™m not sure if the hubitat hub uses 2.1 or 2.5 you would have to check
Andy
You can also get something like this if you're handy at soldering, and if you're not you can get some of these. I've used both for when I need to go in-wall with a power adapter cable.
I order similar to this for the cable itself.
Of course if you're only going to do this once and you need just over 6 feet, then the 16 foot option Andy pointed you to is easier and much less expensive.
Whatever happened to the good ol' extension cord? :slight_smile:
Cut the power cable in half. Use regular old speaker wire to join the 2 pieces together, making sure you have the polarity correct, and close the "joins" properly with electrical tape / heat shrink tubing. Why complicate matters?
J
