I checked and Jason0x43 doesn't have the Fan mode supported. I am adding that to the code and will send after I verify it working.
This has a small change to make the Fan mode work. At least it does in my house
Just replace the nest driver only from Jason's Nest Code.
Sorry for the slow reply. I was so tired from the conference last week that I replied in email vs coming here to reply. I loaded the code but have not had time to test much with it. Hopefully over the next couple of days or so. Thanks
No problem, 2 things: I switched to the nst integration app for long term, personally. And I refactored keenect to this Keenect Lite (Release)
It is a lot simpler in code and usage. You use your nest/household thermostat in the master, and create a virtual thermostat for each zone.
I will continue to support this version, but if there is any future development, I will do it in the lite version.
We had house guests for a few days but they left this morning so I can experiment again
How do I create a virtual thermostat? I have motion/temp sensors but I am not sure how to make the temp sensory a virtual thermostat.
under devices, click add virtual device
then fill out the info: type is virtual thermostat
you are only using the thermostat for the setpoints for your vent, the temp sensor is your real sensor in the zone
