Porting a driver for Yeelight Local Control
The included Yeelight Integration in Hubitat unfortunately doesn't support the Yeelight ylxd50yl (which is odd in the yeelight ecosystem because it has a primary light and an "ambilight". As I can't change the standard Yeelight integration, I've been trying to port a driver I had from SmartThings and I'm getting an error I don't understand. It's my first port so please play nice...
Here's the code:
metadata {
	definition (name: "Yeelight", namespace: "simontether", author: "Simon Tether", mnmn: "SmartThings", vid: "generic-rgbw-color-bulb") {
		capability "Switch Level"
		capability "Color Control"
		capability "Color Temperature"
		capability "Switch"
        	capability "Relay Switch"
		capability "Refresh"
		capability "Actuator"
		capability "Sensor"
		command "reset"
        	command "refresh"
        	attribute "colorName", "string"  //Needed for Colour Shortcuts
        	command "coolWhite"
        	command "warmWhite"
		command "daylight"
		command "red"
        	command "green"
        	command "blue"
        	command "cyan"
        	command "magenta"
        	command "orange"
        	command "purple"
        	command "yellow"
        	command "pink"
        	command "police"
        	command "alarm"
        	command "colourcycle"
        	command "halt"
	simulator {
    //Tiles on Device Panel
	standardTile("switch", "device.switch", width: 1, height: 1, canChangeIcon: true) {
		state "on", label:'${name}', action:"switch.off", icon:"st.lights.philips.hue-single", backgroundColor:"#00a0dc", nextState:"turningOff"
		state "off", label:'${name}', action:"switch.on", icon:"st.lights.philips.hue-single", backgroundColor:"#ffffff", nextState:"turningOn"
		state "turningOn", label:'${name}', action:"switch.off", icon:"st.lights.philips.hue-single", backgroundColor:"#00a0dc", nextState:"turningOff"
		state "turningOff", label:'${name}', action:"switch.on", icon:"st.lights.philips.hue-single", backgroundColor:"#ffffff", nextState:"turningOn"
	standardTile("refresh", "device.switch", inactiveLabel: false, decoration: "flat") {
		state "default", label:"", action:"refresh.refresh", icon:"st.secondary.refresh"
	standardTile("reset", "device.reset", inactiveLabel: false, decoration: "flat") {
		state "default", label:"Reset Color", action:"reset", icon:"st.lights.philips.hue-single"
	controlTile("levelSliderControl", "device.level", "slider", height: 1, width: 2, inactiveLabel: false, range:"(0..100)") {
		state "level", action:"switch level.setLevel"
	controlTile("rgbSelector", "device.color", "color", height: 3, width: 3, inactiveLabel: false) {
		state "color", action:"setColor"
	valueTile("level", "device.level", inactiveLabel: false, decoration: "flat") {
		state "level", label: 'Level ${currentValue}%'
	controlTile("colorTempControl", "device.colorTemperature", "slider", height: 1, width: 1, inactiveLabel: false, range:"(2700..6500)") {
		state "colorTemperature", action:"setColorTemperature"
	valueTile("hue", "device.hue", inactiveLabel: false, decoration: "flat") {
		state "hue", label: 'Hue ${currentValue}   '
	standardTile("coolWhite", "device.colorName", height: 1, width: 1, decoration: "flat", inactiveLabel: false, canChangeIcon: false) {
		state "off", label:"cool white", action:"coolWhite", icon:"st.illuminance.illuminance.dark", backgroundColor:"#D8D8D8", defaultState: true
		//state "coolWhite", label:"cool white", action:"off", icon:"st.illuminance.illuminance.bright", backgroundColor:"#FF33CB"
   	standardTile("warmWhite", "device.colorName", height: 1, width: 1, decoration: "flat", inactiveLabel: false, canChangeIcon: false) {
		state "off", label:"warm white", action:"warmWhite", icon:"st.illuminance.illuminance.dark", backgroundColor:"#D8D8D8", defaultState: true
		//state "warmWhite", label:"warm white", action:"off", icon:"st.illuminance.illuminance.bright", backgroundColor:"#FF33CB"
	standardTile("daylight", "device.colorName", height: 1, width: 1, decoration: "flat", inactiveLabel: false, canChangeIcon: false) {
		state "off", label:"daylight", action:"daylight", icon:"st.illuminance.illuminance.dark", backgroundColor:"#D8D8D8", defaultState: true
		//state "daylight", label:"daylight", action:"off", icon:"st.illuminance.illuminance.bright", backgroundColor:"#FF33CB"
	standardTile("red", "device.colorName", height: 1, width: 1, decoration: "flat", inactiveLabel: false, canChangeIcon: false) {
		state "off", label:"red", action:"red", icon:"st.illuminance.illuminance.dark", backgroundColor:"#FF0000", defaultState: true
		//state "red", label:"red", action:"off", icon:"st.illuminance.illuminance.bright", backgroundColor:"#FF0000"
	standardTile("green", "device.colorName", height: 1, width: 1, decoration: "flat", inactiveLabel: false, canChangeIcon: false) {
		state "off", label:"green", action:"green", icon:"st.illuminance.illuminance.dark", backgroundColor:"#00FF00", defaultState: true
		//state "green", label:"green", action:"off", icon:"st.illuminance.illuminance.bright", backgroundColor:"#00FF00"
	standardTile("blue", "device.colorName", height: 1, width: 1, decoration: "flat", inactiveLabel: false, canChangeIcon: false) {
		state "off", label:"blue", action:"blue", icon:"st.illuminance.illuminance.dark", backgroundColor:"#0000FF", defaultState: true
		//state "blue", label:"blue", action:"off", icon:"st.illuminance.illuminance.bright", backgroundColor:"#0000FF"
	standardTile("cyan", "device.colorName", height: 1, width: 1, decoration: "flat", inactiveLabel: false, canChangeIcon: false) {
		state "off", label:"cyan", action:"cyan", icon:"st.illuminance.illuminance.dark", backgroundColor:"#00FFFF", defaultState: true
		//state "cyan", label:"cyan", action:"off", icon:"st.illuminance.illuminance.bright", backgroundColor:"#00FFFF"
	standardTile("magenta", "device.colorName", height: 1, width: 1, decoration: "flat", inactiveLabel: false, canChangeIcon: false) {
		state "off", label:"magenta", action:"magenta", icon:"st.illuminance.illuminance.dark", backgroundColor:"#FF0040", defaultState: true
		//state "magenta", label:"magenta", action:"off", icon:"st.illuminance.illuminance.bright", backgroundColor:"#FF0040"
	standardTile("orange", "device.colorName", height: 1, width: 1, decoration: "flat", inactiveLabel: false, canChangeIcon: false) {
		state "off", label:"orange", action:"orange", icon:"st.illuminance.illuminance.dark", backgroundColor:"#FF6600", defaultState: true
		//state "orange", label:"orange", action:"off", icon:"st.illuminance.illuminance.bright", backgroundColor:"#FF6600"
	standardTile("purple", "device.colorName", height: 1, width: 1, decoration: "flat", inactiveLabel: false, canChangeIcon: false) {
		state "off", label:"purple", action:"purple", icon:"st.illuminance.illuminance.dark", backgroundColor:"#BF00FF", defaultState: true
		//state "purple", label:"purple", action:"off", icon:"st.illuminance.illuminance.bright", backgroundColor:"#BF00FF"
	standardTile("yellow", "device.colorName", height: 1, width: 1, decoration: "flat", inactiveLabel: false, canChangeIcon: false) {
		state "off", label:"yellow", action:"yellow", icon:"st.illuminance.illuminance.dark", backgroundColor:"#FFFF00", defaultState: true
		//state "yellow", label:"yellow", action:"off", icon:"st.illuminance.illuminance.bright", backgroundColor:"#FFFF00"
	standardTile("pink", "device.colorName", height: 1, width: 1, decoration: "flat", inactiveLabel: false, canChangeIcon: false) {
		state "off", label:"pink", action:"pink", icon:"st.illuminance.illuminance.dark", backgroundColor:"#FF33CB", defaultState: true
		//state "pink", label:"pink", action:"off", icon:"st.illuminance.illuminance.bright", backgroundColor:"#FF33CB"
	standardTile("police", "device.colorName", height: 1, width: 1, decoration: "flat", inactiveLabel: false, canChangeIcon: false) {
		state "off", label:"police", action:"police", icon:"st.illuminance.illuminance.dark", backgroundColor:"#0000FF", defaultState: true
	standardTile("alarm", "device.colorName", height: 1, width: 1, decoration: "flat", inactiveLabel: false, canChangeIcon: false) {
		state "off", label:"alarm", action:"alarm", icon:"st.illuminance.illuminance.dark", backgroundColor:"#FF0000", defaultState: true
	standardTile("colourcycle", "device.colorName", height: 1, width: 1, decoration: "flat", inactiveLabel: false, canChangeIcon: false) {
		state "off", label:"colourcycle", action:"colourcycle", icon:"st.illuminance.illuminance.dark", backgroundColor:"#FF0000", defaultState: true
	standardTile("halt", "device.colorName", height: 1, width: 3, decoration: "flat", inactiveLabel: false, canChangeIcon: false) {
		state "off", label:"halt", action:"halt", icon:"st.illuminance.illuminance.dark", backgroundColor:"#FFFFFF", defaultState: true
	main(["switch"])
	details(["switch", "levelSliderControl", "rgbSelector", "reset", "colorTempControl", "refresh",
    	"coolWhite", "warmWhite", "daylight", "red", "green", "blue", "orange", "yellow", "cyan", "magenta", "pink", "purple",
        "police", "alarm", "colourcycle", "halt"])
	//Settings Page
    preferences {
    	input name: "DeviceLocalLan", type: "string", title:"Yeelight IP Address", description:"Enter Bulb's IP address", defaultValue:"", required: true, displayDuringSetup: true
        input name: "defaultONLevel", type: "number", title: "Default ON Level:", description:"Enter Default ON Level", defaultValue:75, range: "1..100", required: false, displayDuringSetup: true
        input name: "coolWhiteValue", type: "number", title: "Cool White Value (K):", description:"Enter Cool White Value", defaultValue:6500, range: "1700..6500", required: false, displayDuringSetup: true
        input name: "warmWhiteValue", type: "number", title: "Warm White Value (K):", description:"Enter Warm White Value", defaultValue:3000, range: "1700..6500", required: false, displayDuringSetup: true
        input name: "dayWhiteValue", type: "number", title: "Daylight White Value (K):", description:"Enter Daylight White Value", defaultValue:4500, range: "1700..6500", required: false, displayDuringSetup: true
def installed()  {
	log.debug "installed"
    	initialize()
def updated()  {
	log.debug "updated"
    	initialize()
//Parse incoming from Yeelight -----NOT WORKING-----
	log.debug "Response '${description}'"
//Reset Yeelight to White, 6000K
def reset() {
	log.debug "reset"
    	//getProp()
    	delayBetween([
		on(),
        	setColor("red":255, "hex":"#FFFFFF", "blue":255, "saturation":100.0, "hue":0.0, "green":255, "alpha":1.0),
        	setColorTemperature(6000)
    	], 300)
//Send Command to Yeelight
def transmit(yeelightCommand) {
        log.debug "sending command to Yeelight:" + DeviceLocalLan
    	def String ipaddr = DeviceLocalLan
    	def String hexIp = ipaddr.tokenize('.').collect {
        String.format('%02X', it.toInteger())
    	}.join()
    	def String myNetworkID = "${hexIp}:D893"
	device.deviceNetworkId = myNetworkID
    	log.debug "network ID: " + myNetworkID
	def transmittedData = new hubitat.device.HubAction(yeelightCommand, hubitat.device.Protocol.LAN, myNetworkID)
	log.debug "Sent " + transmittedData
    	sendHubCommand(transmittedData)
//Get Properties of Yeelight
def getProp() {
	log.debug "getProp"
	transmit("""{"id":1,"method":"get_prop","params":["power", "bright", "ct", "rgb", "name"]}\r\n""")
//Turn Yeelight ON
def on() {
	getProp()
    	delayBetween([
        	transmit("""{"id": 1, "method": "set_power", "params":["on", "smooth", 500]}\r\n"""),
		transmit("""{"id": 1, "method": "set_bright", "params":[${defaultONLevel}, "smooth", 100]}\r\n""")
    	], 300)
    	sendEvent(name: "switch", value: "on")
    	sendEvent(name: "level", value: defaultONLevel)
//Turn Yeelight OFF
def off() {
	getProp()
	transmit("""{"id": 1, "method": "set_power", "params":["off", "smooth", 500]}\r\n""")
    	sendEvent(name: "switch", value: "off")
//Check if Yeelight is off and turn on if it is - called from setLevel, setColor and setColorTemp
def powerCheck() {
	def powerState = device.currentValue("switch")
    	if (powerState == "off") {
    		transmit("""{"id": 1, "method": "set_power", "params":["on", "sudden"]}\r\n""")
//Set Yeelight Dim Level
def setLevel(level) {
	getProp()
    	powerCheck()
	if(level < 2) {
		off()
        	sendEvent(name: "level", value: 0)
    	else {
   		transmit("""{"id": 1, "method": "set_bright", "params":[$level, "smooth", 100]}\r\n""")
        	sendEvent(name: "level", value: level)
//Set Yeelight Colour
def setColor(value) {
	getProp()
    	powerCheck()
	def result = []
    	//transmit("""{"id": 1, "method": "set_power", "params":["on", "smooth", 500]}\r\n""")
    	def red = value.red
    	def green = value.green
    	def blue = value.blue
	log.debug "setColor: ${value}"
    	def rgb = (red*65536)+(green*256)+blue
    	transmit("""{"id": 1, "method": "set_rgb", "params":[${rgb}, "smooth", 500]}\r\n""")
	if(value.hue) sendEvent(name: "hue", value: value.hue)
	if(value.hex) sendEvent(name: "color", value: value.hex)
	if(value.switch) sendEvent(name: "switch", value: value.switch)
	if(value.saturation) sendEvent(name: "saturation", value: value.saturation)
//Set Yeelight Colour Temperature
def setColorTemperature(kelvin) {
	getProp()
    	powerCheck()
	if(kelvin > 6500) kelvin = 6500
    	log.debug "setColorTemperature: ${kelvin}K"
	transmit("""{"id": 1, "method": "set_ct_abx", "params":[${kelvin}, "smooth", 500]}\r\n""")
    	sendEvent(name: "colorTemperature", value: kelvin)
// Colour Shortcuts
def coolWhite() {
    	setColorTemperature(coolWhiteValue)
def warmWhite() {
    	setColorTemperature(warmWhiteValue)
def daylight() {
    	setColorTemperature(dayWhiteValue)
def red() {
	setColor("red":255, "hex":"#FF0000", "blue":0, "saturation":100.0, "hue":0.0, "green":0, "alpha":1.0)
def green() {
	setColor("red":0, "hex":"#00FF00", "blue":0, "saturation":100.0, "hue":0.0, "green":255, "alpha":1.0)
def blue() {
	setColor("red":0, "hex":"#0000FF", "blue":255, "saturation":100.0, "hue":0.0, "green":0, "alpha":1.0)
def cyan() {
	setColor("red":0, "hex":"#00FFFF", "blue":255, "saturation":100.0, "hue":0.0, "green":255, "alpha":1.0)
def magenta() {
	setColor("red":255, "hex":"#FF00FF", "blue":255, "saturation":100.0, "hue":0.0, "green":0, "alpha":1.0)
def orange() {
	setColor("red":255, "hex":"#FFA500", "blue":0, "saturation":100.0, "hue":0.0, "green":69, "alpha":1.0)
def purple() {
	setColor("red":128, "hex":"#800080", "blue":128, "saturation":100.0, "hue":0.0, "green":0, "alpha":1.0)
def yellow() {
	setColor("red":255, "hex":"#FFFF00", "blue":0, "saturation":100.0, "hue":0.0, "green":255, "alpha":1.0)
def pink() {
	setColor("red":255, "hex":"#FFC0CB", "blue":203, "saturation":100.0, "hue":0.0, "green":192, "alpha":1.0)
//Colour Flow Presets
def police() {
	transmit("""{"id":1,"method":"start_cf","params":[0,0,"300,1,16711680,1,50,1,222,1,50,1,3355647,100,50,1,222,1,50,1,16711680,100,50,1,222,1,50,1,3355647,100,50,1,222,1"]}\r\n""")
def alarm() {
	transmit("""{"id":1,"method":"start_cf","params":[0, 0, "500, 1, 255, 100, 500, 1, 16711680,100"]}\r\n""")
def colourcycle() {
	transmit("""{"id":1,"method":"start_cf","params":[0, 0, "5000, 1, 255, 100, 5000, 1, 65280,100, 5000, 1, 16711680,100"]}\r\n""")
def halt() {
	transmit("""{"id":1,"method":"stop_cf","params":[]}\r\n""")
In my logs I'm getting "Cannot get property 'host' on null object" once the http command is sent to the light and the light isn't responding to the command.
I checked all the usual stuff (e.g. Have I got the IP address correct and so on)
Anyone got any ideas?
@mike.maxwell any chance you could lean in and provide a pointer?
why don't we just add support for that specific light?
when you ran the integration and that device was discovered, it should have spit something to the live logs about not knowing what the bulbs capabilities were and therefore we would not include it, there should have been a model number in brackets..., thats the bit i need.
Amazing @mike.maxwell, thank you. The perfect solution! According to my logs it's "ceiling20"
Hi @mike.maxwell did you get the chance to incorporate this into a release?
If its listed in the 2.2.7 release notes then yes, else no...
