I'm attempting to install a remote pool temp sensor embedded in the PVC piping out to my pool.
Any advice how to connect this specific sensor into a water flow switch housing? How do I prevent the temp sensor from pushing out? Is there a special adapter for this? I planned on buying the following items.
A pool or pond forum might be better to check with but... There are simpler methods to house the sensor unless you are trying to monitor temp in a pipe with water flow. If you just want the pool temp you can completely embed the sensor end in a small pvc pipe with cap. Fill it with caulk or hot glue. The bigger problem will be the power plug going to the Fibaro. For that you probably want a case with sealing plug ports, or again just bury any connections in caulk or hot glue.
