I'm wanting to use an ambient temp sensor to control a relay connected to a pool pump. Ive been reading different posts about similar setups and wanted to see if this can be done by a rule.
If temp drops below 34 degrees...turn pool pump relay on
Once temp rises above 34 degrees again.. turn pool pump relay off.
Started thinking that this should be pretty simple but then started to see the posts about the different challenges.
Im trying to think of any other scenarios that would cause problems with this rule.
- once below 32.....will the rule temp triggering..and if so - will that create a problem? Using a HSM 200 which reports temp every minute....i don't suspect that will create an undue amount o traffic on the network?
Any way to disable the rule if there is another activity going on?....as an example. Might want to use the hot tub in colder weather and in that case the pump relay will be turned on via a manual with on the relay or form the dashboard......can i pair the rule with a VS that is activated when the pump is turned on so the rule i inactive?
Anyway - appreciate any thoughts.
regards
mac
