- I'd like instructions to build my own and set them up in HE
- I'd like to buy a pre-built sensor that I would add to HE myself
- Get lost Ryan
tl;dr - I'm gauging interest before putting in the work to write a detailed guide to build an ESPhome-based mmWave radar for pretty cheap. If there's enough interest in it, I'm also toying with the idea of selling pre-built sensors that would just need to be connected to WiFi, added to HE, and configured.
One of the biggest doors that having Home Assistant has opened is the ability to use ESPhome. For me, the biggest win here has been the ability to build mmWave radars, with extremely granular configurations for sensitivity, for extremely cheap. For example, I have several built using:
ESP32-S2 Mini - $1.89
LD2410C radar - $2.71
3D printed case - $0.50
6' USB cable - $3
Add a few dollars for shipping and it's right around $13. Since the shipping costs do not scale when bought in bulk, 100 of these would cost ~$8/each.
The other benefit is that they're small. The configuration above is about 1" tall and 1.5" wide (38.85mm x 29.95 mm). The depth depends on which mounting back is used (I have different ones for mounting the sensor flat, at an angle, in the ceiling corner, and tilted down), but ranges from 0.5" to 1.25" (14mm to 32 mm). There are slight more expensive ESP32 options (~$2.20) that bring this size down even more.
The LD2410C has a built-in Bluetooth module allowing it to be connected to a mobile device and using an app to configure everything with it. The dashboard below is from Home Assistant, but the graphing in the app is extremely similar.
Each number on the x-axis represents a certain distance (0.2m or 0.75m; configurable in the app) with independent threshold settings for detecting movement and still beings (can at least detect 45 lb dogs).
Why do I bring this up:
I still have some HE hubs sitting around. I was toying with the idea of working on getting these sensors integrated into HE and documenting the whole process of building the sensor to integration.
Also, realizing there are folks out there that haven't an appetite for soldering and/or access to a 3D printer, I thought I could bulk order the parts, assemble and complete the initial setup process (installing the ESPhome firmware on the ESP32 board), and sell these for ~$20-25 including shipping ($5 flat rate in the US). This would massively depend on interest. I value my time (like I hope everyone does), so unless I could get enough to drive the parts cost down, then it wouldn't be worth my time to solder, print cases, and setup. A smaller pool would result in a higher price which would negate the big upsell for these (aside from size).
