Piston Runs Sometimes
I have a really simple piston that sets the location to Day and turns off the HSM. However, this piston does not seem to always run. I brought this piston over from SmartThing WebCore and it is doing the same thing now as it previously did. I have no idea why it runs just fine something and not other times.
Here is the log from this morning and it did not run.
1/13/2023, 7:10:00 AM +26ms
+9ms ╔Received event [Home Hub].time = 1673615400000 with a delay of 26ms, canQueue: true, calledMyself: false
+78ms ║RunTime initialize > 77 LockT > 0ms > r9T > 67ms > pistonT > 66ms (first state access 3 m:10 10 67)
+81ms ║Runtime (8402 bytes) initialized in 67ms (v0.3.114.20230103_HE)
+87ms ║╔Execution stage started
+90ms ║║Piston execution aborted due to restrictions in effect; updating piston states
+105ms ║║nullRequesting every schedule wake up at Mon, Jan 16 2023 @ 7:10:00 AM CST (in 259199870ms) for 2 (st:-1)
+106ms ║║Piston Every timer execution aborted due to restrictions in effect
+107ms ║║Exiting piston at end of Every timer block
+111ms ║╚Execution stage complete. (25ms)
+157ms ║Setting up scheduled job for Mon, Jan 16 2023 @ 7:10:00 AM CST (in 259199858ms)
+159ms ╚Event processed successfully (151ms)
See:
and
hint - the restriction is messing you up, code it into the every block vs. have the every block nested underneath it
