@mike.maxwell Is this anything I should be worried about??
This is normally generated when the button count isnt set correctly
It's definitely a 5 button PICO
Huh, can you change it to 3, save that, then back to 5?, see if that kicks it. Also post a picture of the pico, thanks
After 5 mos of fighting with this particular pico I simply binned it. No amount of resets were fixing it. Replaced it today and all is good...
Interestingly, I've been using lutron for over 11 years and never had a device go bad...
