My understanding is that a Pico can be paired directly to a Lutron Caseta dimmer, apart from the Caseta Bridge. Is this true? If so, how many dimmers can be paired to a single Pico? If the Pico is not paired to the Caseta Bridge, then it won’t be counted against the 75 maximum devices supported by the Caseta Bridge, correct?
For a Pico that IS paired to the Caseta Bridge, is there any necessity to have it integrated into Hubitat, if the Pico is only used to directly control a Caseta dimmer?
While you can directly pair a Pico to a Caseta Switch or Dimmer, I have found that the Pico still shows up in the SmartBridge Pro, and does count as one of the 75 devices. I could be recalling this incorrectly…but that is my recollection.
No need to integrate every Pico with Hubitat. I have many that are only used in 3way/4way lighting configs that I chose to not add to Hubitat.
