Physical button press not turning off light that is on
Hi All!
I'm quite new to the whole smart home world, and have been using lights through my Google Home. I decided to add a button to the mix, but am having an issue writing the rule.
When I single press, the light should turn on, if it's off. If the button is pressed when the light is on, it should turn the light off. I have written the following rule. It works to turn the light on, but doesn't turn it off.
What am I doing wrong?
The one thing that I have noticed is, in the device settings, when the light is on / off. It doesn't update the switch state (on the right). When I manually press refresh, it changes it. Then the button works.
In there meant to be a minimum delay before the hub communicates with the device and 'refreshes' its status?
Thanks!
What is the device type for the office light? If ZWave, is it ZWave or ZWave+?
Also, you are missing an END-IF in your rule, but you actually don't need the ELSE-IF/THEN/END-IF. If the light is not off, then you don't need to check again to see if it is on. In other words ..
rule
Use TOGGLE for controlling the light instead. Then you don’t need any logic. :slight_smile:
Don’t know about your status issue. You could try hitting the configure button on the device page to make sure the light has all right parameters.
