Phillips Hue Dimmer Switch Integration?
Has anyone had success getting the Hue Dimmer Switch integrated into hubitat? I know someone was woking on it within SmartThings, but the thing kept loosing connection to the ST Hub. I’d love to get these things on to HE.
You want to use it like a Pico, where some of the buttons control Hue and some control non-Hue, or all control non-Hue?
As long as the button also controls a Hue device, you could also operate other devices with Rules. Just curious why you would want to use Hue Dimmers for instead of Pico for anything other than Hue? Do you have a lot of them already or are they hard to get where you live? I own one, but now that I have Hubitat and a Caséta Pro bridge, I personally would never consider buying another Hue remote.
706 and Pico’s are really fantastic. Instant response. Well worth the cost of the additional Caséta Pro bridge you need.
For those outside the US and Canada, Hue dimmers are likely to be available and Lutron devices are not. :sunglasses:
Yep. It’s a shame. Picos are so much nicer.
I have 2 of them because ST's was so unreliable, so why not use them. They were connected to my Hue Bridge, but I'd love to use them to switch mode and stuff as well.
I installed this device driver and the dimmer was discovered:
Hopefully it stays connected.
With that installed, can you use the Button Controllers app or ABC by @stephack to configure it?
I use the one that I have with Hue lights in my bedroom (my wife likes it, sort of ) and that’s the only reason it hasn’t already been replaced with a Pico. I do like the abilities I get with iConnect Hue app to configure the bridge to allow up to 5 presses per button, plus a hold for each.
The Device doesn't show up for me in this app. I haven't tried ABC
An excellent app. Even if it doesn’t work for the Hue remotes, it makes configuring other supported buttons so much faster than The built-in app.
updated the Device Driver with Capability "Pushable Button" and now both apps find it.
You’re going to need to change the createEvent call too to comply with the Hubitat implementation of Button devices.
Look here for known differences in the platforms
Ugh... Sorry I am not really a developer and probably blind. I don't see what needs to be changed. It's probably right in my face, but sometimes I can't find my wallet which is right in front of me. :slight_smile:
I assume you mean this:
def result = createEvent(name: "button", value: "pushed", data: [buttonNumber: button], descriptionText: "$device.displayName button $button was pushed", isStateChange: true)
I found it. :slight_smile:
def result = createEvent(name: "pushed", value: button, descriptionText: "$device.displayName button $button was pushed", isStateChange: true)
I am not sure why it works though. I am such a hack.
You got it. Nice work!
Is this working well? Did the hue dimmer stay connected to the hub?
I had 1 drop, but I am unsure if it was related to the hardware or just growing pains with the hub.
A built in driver for this will be included in the next build.
Pushed supported on buttons 1 and 4 (on off)
Pushed, Held and Released on buttons 2 and 3, the level buttons.
Oh yeah, and battery level too...
The different capabilities between the on/off and the level buttons is a hardware limitation.
Any idea of this could work with the hue tap as well?
this driver will not work with the tap, no idea if the tap will pair with HE or not.
I am in the market for a remote (battery powered) wall switch, and the hue dimmer looks like a good option. I do not have a hue system. Does the built-in support talk directly with the hue dimmer, or only through the hue hub? Thanks!
Also, I am open to alternatives, provided I dont need yet another hub to integrate it..
I know you said you don’t want another hub....but.... Lutron Pico Remotes are really amazingly flexible, have awesome battery life, great mounting options, and excellent integration with Hubitat via the Caseta SmartBridge Pro2. The picos are so inexpensive, that it offsets the the cost of the SmartBridge Pro2.
