Philips Hue Driver Code Error
Hi all.
Would it be at all possible for someone in 'staff' to address the constant issue I'm having with:
Division by zero on line 800 in the 'createEventsFromMapV1' method in the built in hue driver 'hueBridgeGroup' code
and
Division by zero on line 793 in the 'createEventsFromMapV1' method in the built in hue driver 'hueBridgeBulbRGBW' code...
Thank you
What hub model and what platform/firmware version is it running?
Also, what integration are you using? The built in one I would assume but please confirm.
There are multiple custom Hue integrations that people use, is why I ask.
@bertabcd1234 any ideas?
OP: The Matter link to your HUE bridge may be broken. You can check this in settings > Matter settings.
I see the same thing every few days. Disabling Matter on HE and the enabling it again solves it on my environment.
Hub: C8-Pro
version: 2.4.0.151
Hue Bridge Integration (built in)
Thanks for the suggestion but I don't use matter I have it disabled.
This should already be fixed in 2.4.1, currently in beta (can join if you want to test, otherwise it will be released at some point :slight_smile: ).
