On C7 latest release 2.3.3.121.
done soft reset. Old rules are failing to load
Unexpected Error
An unexpected error has occurred trying to load the app. Check Logs for more information.
Error: Cannot cast object 'null' with class 'null' to class 'int'. Try 'java.lang.Integer' instead
This is the old rules.
On day 1 of each of these months: May,June,July,August: At 12:00
On day 15 of each of these months: May,June,July,August: At 12:00
So i deleted the rule and did soft reset. Now I can't define a new rule like the above.
As far as I can tell only effecting Periodic Schedule rules.
more info. I'm migrating C5 to C7 and I still have access to the C5.
On the C5 rel 2.3.2.141 the rule loads ok. I just upgraded it to rel 2.3.3.121 and now the same rule fails to load.
Hi @bravenel. Iād add to the list a bug with screen reader mode not properly announcing checkboxes and their status in the new tables interface. I hope you can get to it soon. Thanks.
I try to create a new rule(5.1) and get this
*Unexpected Error
log entry as follows:
org.codehaus.groovy.runtime.typehandling.GroovyCastException: Cannot cast object 'null' with class 'null' to class 'int'. Try 'java.lang.Integer' instead on line 1547 (method mainPage)
The new rule is for 1st on month for may, june,july,aug at 12:00. I don't get any further. It's for a Periodic Schedule.
@bravenel
Using a variable in the periodic cron trigger is broken once again. Specifically when the cron variable is updated, the trigger remains the same as previously scheduled. Attached test cron app and log reflects the error when changing from a 5 minute timer to 1 minute timer, the trigger remains at 5 minutes. This was fixed previously in 2.3.2, I noted it in the .122 release and verified it as per the attached in the latest .123 release. Thanks!
