Setting up 2 separate ZigBee switches to operate aquarium pumps on an itermittent basis. Set the first switch up (using Rule Machine): Trigger Event: Every 10 minutes; Actions: On/ then Off delayed 3 minutes. It has been working like a charm for several hours now.
Second switch I "believe" I set up exactly the same, but when I go to the "Scheduled Jobs" under the first switch the time cycle is listing as expected - ten minutes between Previous Run Time and Next Run Time. The second switch shows that the rule is only running once at the top of each hour.
Am I missing something fundamental about how the Rules Machine runs these scheduled jobs, or is there a setting that I likely didn't toggle? I'd appreciate any input on how to troubleshoot this.
