Pending Change - Zwave Device
I had to make some changes to my wifi and I added some repeaters last night which impacted a number of things today. I am getting a message on a zwave device now which I was not expecting to be impacted and its a note in the logs saying:
dev:1542020-10-10 07:18:10.349 pm warnThere are 1 pending change, please click the Save button again.
I have gone into the device and saved the preferences and device name. Is there an obvious reason why this would happen? I do use groups a lot but I thought I had gone in and saved all.
I see this a lot. I just ignore it. No idea if that is a bad thing or not...
This maybe a bug in the device driver. What device type is this from?
I canโ€™t cleanly reproduce it but see it from two zwave devices both which are - EVA LOGIK Smart Plug
  • deviceType: 49152
  • zwaveSecurePairingComplete: true
  • inClusters: 0x5E,0x6C,0x55,0x9F
  • zwNodeInfo: D3 9C 01 04 10 01 5E 6C 55 9F 68 23
  • secureInClusters: 0x86,0x25,0x85,0x8E,0x59,0x72,0x5A,0x73,0x70,0x7A
  • firmwareVersion: 2.1
  • deviceId: 49155
  • S2: 1
  • manufacturer: 786
I have the same thing on my dome flood and contact sensors. Forever pending changes. I don't recall smartthings having this issue
So annoying... I can now reproduce it. When I hit save on the device preference the error will pop. If I just save the device information I will not. It doesnt matter if I change anything or not. Hit save, get the error.
Is the device working as expected?
Yes this device seems to work fine. I have others which are not which sent me down this rabbit hole....
Same problem here with a Fibaro sensor. "Pending Changes" only goes up, but device functions fine and accepted the submitted changes.
Controller Type ZWV
Data * deviceType: 2048
  • inClusters: 0x30,0x84,0x85,0x80,0x8F,0x56,0x72,0x86,0x70,0x8E,0x31,0x9C
  • zwNodeInfo: 53 9C 00 04 20 01 30 84 85 5C 80 8F 56 72 86 70 8E 31 9C 68 23
  • deviceId: 8193
  • MSR: 010F-0800-2001
  • manufacturer: 271|
Same problem here. Pending changes since it's been created.
Do you have the Fibaro FGMS-001 using the Fibaro ZW5 Motion Sensor Driver? My sensor works fine overall but I can't seem to change the sensitivity. I assume this is ConfigVal1 but mine always says "24" not matter what I set the box to be.
