I have a few pella insynctive sensors in our patio door (lock/unlock and door open/closed) but don't have the pella insynctive bridge. Is it possible for hubitat to read the sensors without the hub so I can be alerted if the door is left open or unlocked?
They're 433.92MHz devices - no interaction possible with HE.
So I'd need to get the bridge in order for Hubitat to read them?
No idea if a bridge would work. I have a Bond Bridge and the BB / HE integration is not ideal.
I also have Pella sliding doors. The Slim Strip sensors fit and work well for me. My Slim Strip sensors are branded for my security system, but I see no reason why the standard z wave would not be the same
https://sensative.com/sensors/strips-zwave/strips-guard-700/
No idea, never have used them or tried to integrate those, especially ones that require the insynctive bridge.
That said, there are a couple posts that are interesting and might help. This one I linked below is the most promising...
This isn’t a use case for the Bond bridge. Pella makes their own bridge device for these built-in sensors.
They might fit for OP’s door, but won’t provide the locked/unlocked status monitoring that the built-in sensors do.
Yes.
@neonturbo appears to have linked to the solution.
agreed this has been resolved. Thank you @marktheknife for summarizing it all up and for everyone else's responses!
